Check all device is Off  [Solved]
djdevil
Domoticz version: 2021.1
Post by djdevil »
Hello, I have an automation in mind but I am unable to write it. I ask for help!
the script should start by activating a virtual key.
It should check that all the lights and shutters are in an off state. If a device is on a different state from the one on, it sends me a notification with the device name and its status.
while if everything is off send a message that everything is ok.
You could facilitate the script by adding the devices to query with the addition of its idx. thank you
Re: Check all device is Off
djdevil wrote: Tuesday 04 February 2020 11:59 the script should start by activating a virtual key.
Could look like something below. ( This version can check for On and Off states but can easily extended with other state-checks by adding tables and add the new table names to devicesToCheck and new required state strings to requiredStates )
return
    on =
        devices =
            'checkStates', -- change to name of (virtual) activation switch
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'check States',
    execute = function(dz)
        local offDevicesToCheck = { 83, 'Alarm clock', 63, 'RGBWWTest'} -- name or id of devices to check for Off state
        local onDevicesToCheck = { 70, 69, 'RGBTest'} -- name or id of devices to check for On state
        --- No changes required below this line
        local devicesToCheck = { offDevicesToCheck, onDevicesToCheck}
        local allDeviceStatesOK = true
        local requiredStates = { 'Off', 'On' }
        for checkTableID, stateTable in ipairs(devicesToCheck) do
            requiredState = requiredStates[checkTableID]
            for _, deviceIdentifier in ipairs(stateTable) do
                local device = dz.devices(deviceIdentifier)
                local state = device.state
                local name = device.name
                if state ~= requiredState then
                    allDeviceStatesOK = false
                    dz.log('Device ' .. name .. ' has wrong state (' .. state .. ')', dz.LOG_DEBUG)
                    dz.notify('StateChecker', 'Device ' .. name .. ' has wrong state (' .. state .. ')', dz.PRIORITY_NORMAL)
        if allDeviceStatesOK then
            dz.log('Devices are all in the required state', dz.LOG_DEBUG)
            dz.notify('StateChecker', 'Devices are all in the required state' , dz.PRIORITY_NORMAL)
djdevil
Post by djdevil »
thank you so much for your work and for the help, in case I have the blinds that report the percentage as well as the lights as I can verify?
djdevil wrote: Tuesday 04 February 2020 14:04 In case I have the blinds that report the percentage as well as the lights as I can verify?
What is the state you want to check ? What do you get as notification or see in the log when checking for On or Off state ?
djdevil
Post by djdevil »
A practical example would be that if I close the roller shutter and it locks and remains at 50% or I have dimmable lights that if they do not go out, their status is set to 30%
djdevil wrote: Tuesday 04 February 2020 14:19 A practical example would be that if I close the roller shutter and it locks and remains at 50% or I have dimmable lights that if they do not go out, their status is set to 30%
Sorry but I stil don't get it.
Should the script notify you when the level of the shutter is 50% or should it notify when it is not equal to 50 %
djdevil
Post by djdevil »
It should be noted that the roller shutter has not been closed and that it is 50% the same as the light has never been turned off and 30% water is found
djdevil wrote: Tuesday 04 February 2020 14:53 It should be noted that the roller shutter has not been closed and that it is 50% the same as the light has never been turned off and 30% water is found
Probably a language thing and with a risk that I am repeating myself:
The script looks for a certain state in a device. If the state found is different then what you defined as required it notifies you.
So what is the state you require ?
Is it Off, Closed or something else ?
djdevil
Post by djdevil »
Ok then my mistake I understood tonight I will go home and try the script and let you know
djdevil
Post by djdevil »
waaren I studied the code! I understood that everything works perfectly. Notifications arrive perfectly!
os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione  ' .. name .. ' è acceso"')
Now I use this code to announce to alexa the devices on or closed, but you only have one, what should I do?
This all code
return
    on =
        devices =
            'Controllo Casa', -- change to name of (virtual) activation switch
    logging =
       local offDevicesToCheck = { 151, 66,127,} -- name or id of devices to check for Off state
      local onDevicesToCheck = {40 } -- name of blind check if close
     local requiredStates = { 'Off', 'Closed' }
                    os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione  ' .. name .. ' è acceso"') -- Speak Alexa code
Alexa should announce the names of powered on or open devices
djdevil wrote: Tuesday 04 February 2020 21:40 Now I use this code to announce to alexa the devices on or closed, but you only have one, what should I do?
Sorry I don't understand what you mean. Please explain in more detail.
In general it is not a good idea to use external commands (like os.execute) in a loop. It potentially can block the entire event system.
My suggestion is to create a string in the loop and send that to the /home/pi/domoticz/alexa_remote_control.sh script when the loop finished.
the dzVents could look like
return
    on =
        devices =
    logging =
        local alexaString = {}
                    table.insert(alexaString, name)
            -- Speak Alexa code (& is to process command in background)
            os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione  '  .. table.concat(alexaString, ' and ') .. ' è acceso"  &')
djdevil
Re: Check all device is Off  [Solved]
Post by djdevil »
waaren wrote: Wednesday 05 February 2020 1:35
Sorry for my English!
With your last modification on the code I can do what I thought.
In practice, when a virtual button is activated, there is a control of open or on devices, if all goes well alexa announces the message that everything is closed and off or announces the names of the devices in an error state!
Perfect Thank you very much I hope it will serve everyone.
If you want you can change the title of the post more appropriately. Thank you 8-)
djdevil
Post by djdevil »
hello waaren I perfectly use the code written by you long ago, now I need to make a change. in practice, in summer I never completely close the shutters and therefore my 7 shutters are all positioned with a different percentage. how can i get it to check the percentage level? instead if open or closed?
return
    on =
        devices =
    logging =
[/quote]
Blind percentage position can be get with .level (or .lastlevel)
See for more info the dzVents wiki.
