Check all device is Off [Solved]
- djdevil
- Domoticz version: 2021.1
Hello, I have an automation in mind but I am unable to write it. I ask for help!
the script should start by activating a virtual key.
It should check that all the lights and shutters are in an off state. If a device is on a different state from the one on, it sends me a notification with the device name and its status.
while if everything is off send a message that everything is ok.
You could facilitate the script by adding the devices to query with the addition of its idx. thank you
- waaren
Re: Check all device is Off
Could look like something below. ( This version can check for On and Off states but can easily extended with other state-checks by adding tables and add the new table names to devicesToCheck and new required state strings to requiredStates )djdevil wrote: Tuesday 04 February 2020 11:59 the script should start by activating a virtual key.
return
on =
devices =
'checkStates', -- change to name of (virtual) activation switch
logging =
level = domoticz.LOG_DEBUG,
marker = 'check States',
execute = function(dz)
local offDevicesToCheck = { 83, 'Alarm clock', 63, 'RGBWWTest'} -- name or id of devices to check for Off state
local onDevicesToCheck = { 70, 69, 'RGBTest'} -- name or id of devices to check for On state
--- No changes required below this line
local devicesToCheck = { offDevicesToCheck, onDevicesToCheck}
local allDeviceStatesOK = true
local requiredStates = { 'Off', 'On' }
for checkTableID, stateTable in ipairs(devicesToCheck) do
requiredState = requiredStates[checkTableID]
for _, deviceIdentifier in ipairs(stateTable) do
local device = dz.devices(deviceIdentifier)
local state = device.state
local name = device.name
if state ~= requiredState then
allDeviceStatesOK = false
dz.log('Device ' .. name .. ' has wrong state (' .. state .. ')', dz.LOG_DEBUG)
dz.notify('StateChecker', 'Device ' .. name .. ' has wrong state (' .. state .. ')', dz.PRIORITY_NORMAL)
if allDeviceStatesOK then
dz.log('Devices are all in the required state', dz.LOG_DEBUG)
dz.notify('StateChecker', 'Devices are all in the required state' , dz.PRIORITY_NORMAL)
}Debian buster, bullseye on RPI-4, Intel NUC.
- djdevil
thank you so much for your work and for the help, in case I have the blinds that report the percentage as well as the lights as I can verify?
- waaren
What is the state you want to check ? What do you get as notification or see in the log when checking for On or Off state ?djdevil wrote: Tuesday 04 February 2020 14:04 In case I have the blinds that report the percentage as well as the lights as I can verify?
- djdevil
A practical example would be that if I close the roller shutter and it locks and remains at 50% or I have dimmable lights that if they do not go out, their status is set to 30%
- waaren
Sorry but I stil don't get it.djdevil wrote: Tuesday 04 February 2020 14:19 A practical example would be that if I close the roller shutter and it locks and remains at 50% or I have dimmable lights that if they do not go out, their status is set to 30%
Should the script notify you when the level of the shutter is 50% or should it notify when it is not equal to 50 %
- djdevil
It should be noted that the roller shutter has not been closed and that it is 50% the same as the light has never been turned off and 30% water is found
- waaren
Probably a language thing and with a risk that I am repeating myself:djdevil wrote: Tuesday 04 February 2020 14:53 It should be noted that the roller shutter has not been closed and that it is 50% the same as the light has never been turned off and 30% water is found
The script looks for a certain state in a device. If the state found is different then what you defined as required it notifies you.
So what is the state you require ?
Is it Off, Closed or something else ?
- djdevil
Ok then my mistake I understood tonight I will go home and try the script and let you know
- djdevil
waaren I studied the code! I understood that everything works perfectly. Notifications arrive perfectly!
Now I use this code to announce to alexa the devices on or closed, but you only have one, what should I do?
This all code
Alexa should announce the names of powered on or open devices
os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione ' .. name .. ' è acceso"')This all code
return
on =
devices =
'Controllo Casa', -- change to name of (virtual) activation switch
logging =
local offDevicesToCheck = { 151, 66,127,} -- name or id of devices to check for Off state
local onDevicesToCheck = {40 } -- name of blind check if close
local requiredStates = { 'Off', 'Closed' }
os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione ' .. name .. ' è acceso"') -- Speak Alexa code
}- waaren
Sorry I don't understand what you mean. Please explain in more detail.djdevil wrote: Tuesday 04 February 2020 21:40 Now I use this code to announce to alexa the devices on or closed, but you only have one, what should I do?
In general it is not a good idea to use external commands (like os.execute) in a loop. It potentially can block the entire event system.
My suggestion is to create a string in the loop and send that to the /home/pi/domoticz/alexa_remote_control.sh script when the loop finished.
the dzVents could look like
return
on =
devices =
logging =
local alexaString = {}
table.insert(alexaString, name)
-- Speak Alexa code (& is to process command in background)
os.execute('/home/pi/domoticz/alexa_remote_control.sh -d "Alexa Studio" -e speak:"Attenzione ' .. table.concat(alexaString, ' and ') .. ' è acceso" &')
- djdevil
Re: Check all device is Off [Solved]
waaren wrote: Wednesday 05 February 2020 1:35Sorry I don't understand what you mean. Please explain in more detail.djdevil wrote: Tuesday 04 February 2020 21:40 Now I use this code to announce to alexa the devices on or closed, but you only have one, what should I do?
Sorry for my English!
With your last modification on the code I can do what I thought.
In practice, when a virtual button is activated, there is a control of open or on devices, if all goes well alexa announces the message that everything is closed and off or announces the names of the devices in an error state!
Perfect Thank you very much I hope it will serve everyone.
If you want you can change the title of the post more appropriately. Thank you![]()
- djdevil
hello waaren I perfectly use the code written by you long ago, now I need to make a change. in practice, in summer I never completely close the shutters and therefore my 7 shutters are all positioned with a different percentage. how can i get it to check the percentage level? instead if open or closed?
[/quote]
return
on =
devices =
logging =
}- waltervl
- Domoticz version: 2025.1
Blind percentage position can be get with .level (or .lastlevel)
See for more info the dzVents wiki.
