ZiGate adding AqaraWall Switch (not detected)
egrueda
Post by egrueda »
Hi all, I'm moving from xiaomi gateway to a Zigate USB adapter.
I've succesfuly migrated door sensor, smart socket and small rounded switch.
But I am not able to pair a simple Aqara Single Wall Switch
Model code is WXKG03LM, which is "Fully operationnal" according to thje plugin wiki
But I just can't get to pair it.
I've enabled verbose debug, I put the zigbee adapter in join mode, blue led blinks.
Then I try to click my switch but get no log
I click 5 times, no luck
I press for 10 seconds, it shows nothing.
Am I missing something?
Please, can you help?
pipiche
Re: ZiGate adding AqaraWall Switch (not detected)
Post by pipiche »
It should pair.
Does the Xiaomi gw still on ? If so try to power off
Does the switch is not far from the zigate ?
When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
pipiche
Post by pipiche »
egrueda wrote: Sunday 19 January 2020 12:04 Hi all, I'm moving from xiaomi gateway to a Zigate USB adapter.
Could you provide the log. Is there anything happening ?
egrueda
Post by egrueda »
Nothing in the log :-(
I'm using verbose=2 and there's absolutely nothing
pipiche
Post by pipiche »
It should pair.
egrueda
Post by egrueda »
Sorry, @pipiche, didn't see your answer
pipiche wrote: Sunday 19 January 2020 20:25It should pair.
All my other aqara devices have paired easily :-(
pipiche wrote: Sunday 19 January 2020 20:25Does the Xiaomi gw still on ? If so try to power off
Xiaomi hw is off from the begining.
pipiche wrote: Sunday 19 January 2020 20:25Does the switch is not far from the zigate ?
Both are close, about 15 cm or less
pipiche wrote: Sunday 19 January 2020 20:25When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
Yes, I can see leds flashing, but nothing in the log
I've enabled web interface for the plugin, updated firmware and plugin.
And have enought knowledge to run commands and move through the system, so I can send you what you need and make all testing.
Hope you can point me in the right direction.
Thanks in advance
egrueda
Post by egrueda »
Damn! it was a hardware issue!
I've removed the battery from the switch for about half an hour.
When I put the battery again, zigate felt a disturbance in the Force and log information started to arrive.
All is working now, easily. So I think there was somethin wrong with the switch itself, but couldn't explain more.
Thank you very much!
pipiche
Post by pipiche »
Great news
