Hi all, I'm moving from xiaomi gateway to a Zigate USB adapter.
I've succesfuly migrated door sensor, smart socket and small rounded switch.
But I am not able to pair a simple Aqara Single Wall Switch
Model code is WXKG03LM, which is "Fully operationnal" according to thje plugin wiki
But I just can't get to pair it.
I've enabled verbose debug, I put the zigbee adapter in join mode, blue led blinks.
Then I try to click my switch but get no log
I click 5 times, no luck
I press for 10 seconds, it shows nothing.
Am I missing something?
Please, can you help?
ZiGate adding AqaraWall Switch (not detected)
Re: ZiGate adding AqaraWall Switch (not detected)
It should pair.
Does the Xiaomi gw still on ? If so try to power off
Does the switch is not far from the zigate ?
When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
egrueda wrote: Sunday 19 January 2020 12:04 Hi all, I'm moving from xiaomi gateway to a Zigate USB adapter.
Could you provide the log. Is there anything happening ?
Nothing in the log
I'm using verbose=2 and there's absolutely nothing
It should pair.
Sorry, @pipiche, didn't see your answer
I've enabled web interface for the plugin, updated firmware and plugin.
And have enought knowledge to run commands and move through the system, so I can send you what you need and make all testing.
Hope you can point me in the right direction.
Thanks in advance
All my other aqara devices have paired easily
Xiaomi hw is off from the begining.
Both are close, about 15 cm or less
Yes, I can see leds flashing, but nothing in the logpipiche wrote: Sunday 19 January 2020 20:25When doing the reset ( more than 8s) do you have the switch led turning red or flashing ?
Thanks in advance
Damn! it was a hardware issue!
I've removed the battery from the switch for about half an hour.
When I put the battery again, zigate felt a disturbance in the Force and log information started to arrive.
All is working now, easily. So I think there was somethin wrong with the switch itself, but couldn't explain more.
Thank you very much!
