I need a script (blockly preferred) to turn off a wall plug when the device connected is under a specific watt value for 30 minutes. The device is standby when using 5 watt, when it is active it's using more than 700 watt. So when it's reaching 700 watt within 30 minutes the 30 minutes counter should be cleared, and when it's not reaching this value again within 30 minutes it should turn off.
Can someone please help me?!
Need a script to turn off device when under specific watt value
joostvanmeurs
wouterlet
Re: Need a script to turn off device when under specific watt value
What did you try already? What kind of script do you want? Blocky Dzvents, Lua?
DutchHans
I have something like that in Lua, be more specific in your question.
Regards,Hans
Regards,Hans
freijn
- Domoticz version: Stable
Hans, I think you could use this as a start ? (Garage Door ( blocky won't be able doing this I believe ))
https://www.domoticz.com/wiki/Event_script_examples
test on how to retrieve the consumed power, then test how to switch off.
And most of all, how will it be on again?
- Phantom
- Domoticz version: 4.11652
Hi, maybe this will help you getting started: https://www.domoticz.com/forum/viewtopi ... 72#p164572
wouterlet
Sorry I see you prefer blocky, maybe this one helps?
https://www.domoticz.com/forum/viewtopi ... 96#p225737
