Need a script to turn off device when under specific watt value
joostvanmeurs
Post by joostvanmeurs »
I need a script (blockly preferred) to turn off a wall plug when the device connected is under a specific watt value for 30 minutes. The device is standby when using 5 watt, when it is active it's using more than 700 watt. So when it's reaching 700 watt within 30 minutes the 30 minutes counter should be cleared, and when it's not reaching this value again within 30 minutes it should turn off.
Can someone please help me?!
wouterlet
Re: Need a script to turn off device when under specific watt value
Post by wouterlet »
What did you try already? What kind of script do you want? Blocky Dzvents, Lua?
DutchHans
Post by DutchHans »
I have something like that in Lua, be more specific in your question.
Regards,Hans
freijn
Domoticz version: Stable
Post by freijn »
Hans, I think you could use this as a start ? (Garage Door ( blocky won't be able doing this I believe ))
https://www.domoticz.com/wiki/Event_script_examples
test on how to retrieve the consumed power, then test how to switch off.
And most of all, how will it be on again?
Phantom
Domoticz version: 4.11652
Post by Phantom »
Hi, maybe this will help you getting started: https://www.domoticz.com/forum/viewtopi ... 72#p164572
wouterlet
Post by wouterlet »
Sorry I see you prefer blocky, maybe this one helps?
https://www.domoticz.com/forum/viewtopi ... 96#p225737
