[WORKAROUND] Group of shutters show as "lights" in Dashticz - How to change?
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Hi All,
I am having some trouble getting the shutter (Venetian blinds) groups (defined in Domoticz) to show up as shutters in Dashticz. They show as a light switches which means I can't fully control the groups. I would like to be able to stop the shutters going up or down but I am missing the controls to do so. I do have the controls on the individual shutters as you can see in the screenshot below.
I tried to change the type in Domoticz from "group" to "scene" but that didn't change much.
Is there a way to have the groups show up as shutters in Dashticz?
A screenshot to explain what I mean:
(Luikensets = group of shutters
Luiken = shutters
for those who are not fluent in Dutch ;) )
Below the CONFIG.js showing the general settings and the settings for the shutters:
// Algemene configuratie
var config = {}
config['domoticz_ip'] = 'http://<stripped>';
config['login_timeout'] = '60';
config['user_name'] = 0;
config['pass_word'] = 0;
config['app_title'] = '<stripped.';
config['room_plan'] = 0;
config['default_news_url'] = 'https://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'default';
config['background_image'] = 'img/bg14.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['speak_lang'] = 'en-US';
config['wu_api'] = '<stripped>';
config['wu_city'] = '<stripped>';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['owm_cnt'] = '4';
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['hide_mediaplayer'] = 0;
// Screen definitions
var max_resolution_desktop    = 'default';
var max_resolution_smart      = 'tablet';
// Title Definitions
var title_lampen              = 'title_lampen';
var title_dimmers             = 'title_dimmers';
var title_lampen_2200         = 'title_lampen_2200';
var title_vochtsensors        = 'title_vochtsensors';
var title_ventilator1         = 'title_ventilator1';
var title_rookmelders         = 'title_rookmelders';
var title_gas_en_elektra      = 'title_gas_en_elektra';
var title_luikensets          = 'title_luikensets';
var title_luiken              = 'title_luiken';
var title_datum_tijd          = 'title_datum_tijd'
var title_weer                = 'title_weer';
var title_klimaatsensors      = 'title_klimaatsensors';
var title_deurbel             = 'title_deurbel';
var title_raspberry           = 'title_raspberry';
var title_overige_schakelaars = 'title_overige_schakelaars';
// IDX Definitions
// Luiken
var luik_keuken                = 63;
var luik_dressoir              = 67;
var luik_haard                 = 68;
var luik_kop_tuin              = 69;
var luik_tuindeur              = 70;
var luik_tuinraam              = 71;
var luik_secretaire            = 72;
var luik_eettafel              = 77;
var luik_hobby_waterzijde      = 80;
var luik_hobby_kop             = 81;
// Luikensets (Scenes)
var luiken_waterzijde          = 's1';
var luiken_tuinzijde           = 's2';
var luiken_hobby               = 's3';
// Lampenset
var lampen_2200                = 's4';
// Blocks
var blocks = {}
// Lampen
// Lampen uit om 22.00 uur
blocks['lampen_2200'] = {}
blocks['lampen_2200']['title'] = 'Lampen uit om 22.00';
blocks['lampen_2200']['width'] = 6;
blocks['lampen_2200']['hide_data'] = true;
//Rolluiken
// Title Luikensets
blocks[title_luikensets] = {}
blocks[title_luikensets]['type'] = 'blocktitle'
blocks[title_luikensets]['title'] = 'Luikensets'
// Luikenset - Waterzijde
blocks['luiken_waterzijde'] = {}
blocks['luiken_waterzijde']['title'] = 'Waterzijde';
blocks['luiken_waterzijde']['width'] = 6;
blocks['luiken_waterzijde']['hide_data'] = true;
// Luikenset - Tuinzijde
blocks['luiken_tuinzijde'] = {}
blocks['luiken_tuinzijde']['title'] = 'Tuinzijde';
blocks['luiken_tuinzijde']['width'] = 6;
blocks['luiken_tuinzijde']['hide_data'] = true;
// Luikenset - Hobby
blocks['luiken_hobby'] = {}
blocks['luiken_hobby']['title'] = 'Hobby';
blocks['luiken_hobby']['width'] = 6;
blocks['luiken_hobby']['hide_data'] = true;
// Title Luiken
blocks[title_luiken] = {}
blocks[title_luiken]['type'] = 'blocktitle'
blocks[title_luiken]['title'] = 'Luiken'
// Luiken - Secretaire
blocks[luik_secretaire] = {}
blocks[luik_secretaire]['width'] = 4;
blocks[luik_secretaire]['title'] = 'Secretaire'
blocks[luik_secretaire]['protected'] = false;
// Luiken - Eettafel
blocks[luik_eettafel] = {}
blocks[luik_eettafel]['width'] = 4;
blocks[luik_eettafel]['title'] = 'Eettafel'
blocks[luik_eettafel]['protected'] = false;
// Luiken - Tuin Raam
blocks[luik_tuinraam] = {}
blocks[luik_tuinraam]['width'] = 4;
blocks[luik_tuinraam]['title'] = 'Tuinraam'
blocks[luik_tuinraam]['protected'] = false;
// Luiken - Tuin Deur
blocks[luik_tuindeur] = {}
blocks[luik_tuindeur]['width'] = 4;
blocks[luik_tuindeur]['title'] = 'Tuindeur'
blocks[luik_tuindeur]['protected'] = false;
// Luiken - Kop Tuin
blocks[luik_kop_tuin] = {}
blocks[luik_kop_tuin]['width'] = 4;
blocks[luik_kop_tuin]['title'] = 'Kop Tuin'
blocks[luik_kop_tuin]['protected'] = false;
// Luiken - Haard
blocks[luik_haard] = {}
blocks[luik_haard]['width'] = 4;
blocks[luik_haard]['title'] = 'Haard'
blocks[luik_haard]['protected'] = false;
// Luiken - Dressoir
blocks[luik_dressoir] = {}
blocks[luik_dressoir]['width'] = 4;
blocks[luik_dressoir]['title'] = 'Dressoir'
blocks[luik_dressoir]['protected'] = false;
// Luiken - Keuken
blocks[luik_keuken] = {}
blocks[luik_keuken]['width'] = 4;
blocks[luik_keuken]['title'] = 'Keuken'
blocks[luik_keuken]['protected'] = false;
// Luiken - Hobby Waterzijde
blocks[luik_hobby_waterzijde] = {}
blocks[luik_hobby_waterzijde]['width'] = 4;
blocks[luik_hobby_waterzijde]['title'] = 'Hobby W'
blocks[luik_hobby_waterzijde]['protected'] = false;
// Luiken - Hobby Kop
blocks[luik_hobby_kop] = {}
blocks[luik_hobby_kop]['width'] = 4;
blocks[luik_hobby_kop]['title'] = 'Hobby K'
blocks[luik_hobby_kop]['protected'] = false;
// Columns
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, theaterspot, title_dimmers, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuinzijde, luiken_waterzijde, luiken_hobby, lampen_2200, title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [title_gas_en_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal, grafiek_gas, gas]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [title_klimaatsensors, regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter, title_deurbel, deurbel, title_rookmelders, rookmelder_gang, title_vochtsensors, vochtsensor_ontvochtiger, vochtsensor_cv_ketel, vochtsensor_waterontharder, vochtsensor_wasmachine]
columns[3]['width'] = 3;
//columns[4] = {}
//columns[4]['blocks'] = [title_overige_schakelaars]
//columns[4]['width'] = 12;
// Screens
var screens = {}
// Desktop
screens[max_resolution_desktop] = {}
screens[max_resolution_desktop]['maxwidth'] = 1920;
screens[max_resolution_desktop]['maxheight'] = 1200;
screens[max_resolution_desktop][1] = {}
screens[max_resolution_desktop][1]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][1]['columns'] = [1,2,3]
//screens[max_resolution_desktop][2] = {}
//screens[max_resolution_desktop][2]['background'] = 'img/bg15.jpg';
//screens[max_resolution_desktop][2]['columns'] = [4]
// Tablet
screens[max_resolution_smart] = {}
screens[max_resolution_smart]['maxwidth'] = 1440;
screens[max_resolution_smart]['maxheight'] = 900;
screens[max_resolution_smart][1] = {}
screens[max_resolution_smart][1]['background'] = 'img/bg.jpg';
screens[max_resolution_smart][1]['columns'] = [1,2,3]
I hope you can help fix this.
TIA
Greetz,
Sjonnie
Last edited by Sjonnie2017 on Friday 03 January 2020 16:59, edited 2 times in total.
YouLess Energy meter
Lokonli
Re: Group of shutters show as "lights" in Dashticz - How to change?
Post by Lokonli »
You can change the icon via the icon or image parameter in the block definition in CONFIG.js
See
https://dashticz.readthedocs.io/en/mast ... locks.html
Sjonnie2017
Hi Lokonli,
Thanks for your reply and suggestion. I tried to change the image using the following code in the blocks section:
// Title Luikensets
blocks[luiken_waterzijde] = {}
blocks[luiken_waterzijde]['title'] = 'Waterzijde';
blocks[luiken_waterzijde]['width'] = 6;
blocks[luiken_waterzijde]['hide_data'] = true;
blocks[luiken_tuinzijde] = {}
blocks[luiken_tuinzijde]['title'] = 'Tuinzijde';
blocks[luiken_tuinzijde]['width'] = 6;
blocks[luiken_tuinzijde]['hide_data'] = true;
blocks[luiken_hobby] = {}
blocks[luiken_hobby]['title'] = 'Hobby';
blocks[luiken_hobby]['width'] = 6;
blocks[luiken_hobby]['iconOn'] = 'img/blinds_closed.png'; <-- added this but no success
blocks[luiken_hobby]['iconOff'] = 'img/blinds_open.png'; <-- added this but no success
blocks[luiken_hobby]['hide_data'] = true;
// Title Luiken
Unfortunately I can't get the icons to show the way I want (coding skills of a Kangaroo :oops: )
Apart from my lack of coding skills I fear I have been unsuccessful to explain what I would like to achieve. So I have created a "screenshot" of what I would ultimately like to have :)
Is that possible or am I on a "mission impossible" here?
Looking forward to your reply!
Greetz,
Sjonnie
Lokonli
Post by Lokonli »
With Dashticz everything is possible :)
The icon parameters are for icons from fontawesome.com
For images you can use the imageOn and imageOff parameters.
All image parameters should contain the image filename relative to the 'img/' location, so you have to remove the 'img/' part from your filenames.
Sjonnie2017
Good to know that with Dashticz everything is possible because I am almost there but not quite :P
I got the "image" part working so there is progress ;) I now have the right icons/images on the groups. For those equally "noobed" as I am, here is the code in my CONFIG.js:
// Title Luikensets
blocks[luiken_waterzijde]['imageOff'] = 'blinds_open.png';
blocks[luiken_waterzijde]['imageOn'] = 'blinds_closed.png';
blocks[luiken_waterzijde]['hide_data'] = false;
blocks[luiken_tuinzijde]['imageOff'] = 'blinds_open.png';
blocks[luiken_tuinzijde]['imageOn'] = 'blinds_closed.png';
blocks[luiken_tuinzijde]['hide_data'] = false;
blocks[luiken_hobby]['imageOff'] = 'blinds_open.png';
blocks[luiken_hobby]['imageOn'] = 'blinds_closed.png';
blocks[luiken_hobby]['hide_data'] = false;
Unfortunately I cannot get the controls to show up on the groups (see my second screen dump in my previous post). I would really love to be able to control my shutter groups the same way I can control my individual shutters. Do you have a tip as to how to get this done?
Thank you for your continued support!!
Greetz,
Sjonnie
Lokonli
Post by Lokonli »
The easiest way is to create a dummy device in Domoticz, and to use that device in combination with some scripting to control the real blinds in Domoticz.
Sjonnie2017
Thanks. I am not sure that's the road I would like to go. It looks like a workaround for something that works out of the box in Domoticz.
I have functioning/working scenes in Domoticz where the group of shutters close if I press the "On" switch. If I press the "On" switch again the closing stops. The same for opening a group of shutters. In Dashticz I have only one button. If I press it to close the shutters and during closing I press the button again, the shutters do not stop but they reverse (i.e. are opening again).
Started scrolling through the main.js file and found this section (as of line 1223). I see some code that has been remarked. Further down there seems to be a section that determines what blocks are used given a certain device type in Domoticz. Would it be possible to have my scenes/groups identified as device type Ventian Blinds (EU)?
*snip*
case 'Group':
        case 'Scene':
                        if (device['Type'] === 'Group') $('.block_' + idx).attr('onclick', 'switchDevice(this)');
                        if (device['Type'] === 'Scene') $('.block_' + idx).attr('onclick', 'switchScene(this)');
                        if (device['Status'] === 'Off') html += iconORimage(idx, 'far fa-lightbulb', buttonimg, getIconStatusClass(device['Status']) + ' icon');
                        else html += iconORimage(idx, 'fas fa-lightbulb', buttonimg, getIconStatusClass(device['Status']) + ' icon');
                        html += getBlockData(device, idx, language.switches.state_on, language.switches.state_off);
                        return [html, addHTML];
            return getDefaultSwitchBlock(device, blocks[idx], idx, 'fas fa-lightbulb', 'far fa-lightbulb', buttonimg);
    switch (device['HardwareType']) {
        case 'Toon Thermostat':
            if (device['SubType'] !== 'SetPoint' &&
                device['SubType'] !== 'AC'
                return getSmartMeterBlock(device, idx);
            if (device['SubType'] === 'SetPoint') {
                return getThermostatBlock(device, idx);
            break;
        case 'Logitech Media Server':
            html = getLogitechControls(device);
            $('div.block_' + idx).addClass('with_controls');
    switch (device['SwitchType']) {
        case 'Dimmer':
            return getDimmerBlock(device, idx, buttonimg);
        case 'Door Contact':
        case 'Contact':
            if (device['Status'] === 'Closed') html += iconORimage(idx, 'fas fa-door-closed', '', 'off icon', '', 2);
            else html += iconORimage(idx, 'fas fa-door-open', '', 'on icon', '', 2);
            html += getBlockData(device, idx, language.switches.state_open, language.switches.state_closed);
        case 'Door Lock':
            if (device['Status'] === 'Unlocked') html += iconORimage(idx, 'fas fa-unlock', buttonimg, 'on icon', '', 2);
            else html += iconORimage(idx, 'fas fa-lock', buttonimg, 'off icon', '', 2);
            html += getBlockData(device, idx, language.switches.state_unlocked, language.switches.state_locked);
        case 'Venetian Blinds EU':
        case 'Venetian Blinds US':
        case 'Venetian Blinds EU Inverted':
        case 'Venetian Blinds US Inverted':
        case 'Blinds':
        case 'Blinds Inverted':
            return getBlindsBlock(device, idx, false);
        case 'Blinds Percentage':
        case 'Blinds Percentage Inverted':
        case 'Venetian Blinds EU Percentage':
        case 'Venetian Blinds EU Inverted Percentage':
        case 'Venetian Blinds EU Percentage Inverted':
            return getBlindsBlock(device, idx, true);
        case 'Security': *snip*
If so, can this be used outside main.js (i.e. in /custom/custom.js)? And how would I do that?
I know I am asking a lot and it looks like I don't put in any effort but coding is above and beyond my capabilities :oops:
Greetz,
Sjonnie
Sjonnie2017
Not solved but a acceptable workaround.
I have created 6 new scenes in Domoticz without timers (I have three groups of shutters, each has an on and off state). I left the original scenes (with timers) in Domoticz untouched. Reduced the size of the blocks and assigned them the appropriate images (I don't "do" icons ;) ).
Now I can stop the closing or opening off the shutter groups by pressing the appropriate button again.
All in all a more than acceptable solution. up to the next "challenge" ( :mrgreen:
Greetz,
Sjonnie
madpatrick
Domoticz version: 2026.1
Re: [WORKAROUND] Group of shutters show as "lights" in Dashticz - How to change?
Post by madpatrick »
Is it possible to make the UP/DOWN button and STOP button larger (wider)
My fingers and the thick or my tablet is too small ;-)
