I am having some trouble getting the shutter (Venetian blinds) groups (defined in Domoticz) to show up as shutters in Dashticz. They show as a light switches which means I can't fully control the groups. I would like to be able to stop the shutters going up or down but I am missing the controls to do so. I do have the controls on the individual shutters as you can see in the screenshot below.
I tried to change the type in Domoticz from "group" to "scene" but that didn't change much.
Is there a way to have the groups show up as shutters in Dashticz?
A screenshot to explain what I mean:
(Luikensets = group of shutters
Luiken = shutters
for those who are not fluent in Dutch
Below the CONFIG.js showing the general settings and the settings for the shutters:
// Algemene configuratie
var config = {}
config['domoticz_ip'] = 'http://<stripped>';
config['login_timeout'] = '60';
config['user_name'] = 0;
config['pass_word'] = 0;
config['app_title'] = '<stripped.';
config['room_plan'] = 0;
config['default_news_url'] = 'https://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'default';
config['background_image'] = 'img/bg14.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['speak_lang'] = 'en-US';
config['wu_api'] = '<stripped>';
config['wu_city'] = '<stripped>';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['owm_cnt'] = '4';
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['hide_mediaplayer'] = 0;
// Screen definitions
var max_resolution_desktop = 'default';
var max_resolution_smart = 'tablet';
// Title Definitions
var title_lampen = 'title_lampen';
var title_dimmers = 'title_dimmers';
var title_lampen_2200 = 'title_lampen_2200';
var title_vochtsensors = 'title_vochtsensors';
var title_ventilator1 = 'title_ventilator1';
var title_rookmelders = 'title_rookmelders';
var title_gas_en_elektra = 'title_gas_en_elektra';
var title_luikensets = 'title_luikensets';
var title_luiken = 'title_luiken';
var title_datum_tijd = 'title_datum_tijd'
var title_weer = 'title_weer';
var title_klimaatsensors = 'title_klimaatsensors';
var title_deurbel = 'title_deurbel';
var title_raspberry = 'title_raspberry';
var title_overige_schakelaars = 'title_overige_schakelaars';
// IDX Definitions
// Luiken
var luik_keuken = 63;
var luik_dressoir = 67;
var luik_haard = 68;
var luik_kop_tuin = 69;
var luik_tuindeur = 70;
var luik_tuinraam = 71;
var luik_secretaire = 72;
var luik_eettafel = 77;
var luik_hobby_waterzijde = 80;
var luik_hobby_kop = 81;
// Luikensets (Scenes)
var luiken_waterzijde = 's1';
var luiken_tuinzijde = 's2';
var luiken_hobby = 's3';
// Lampenset
var lampen_2200 = 's4';
// Blocks
var blocks = {}
// Lampen
// Lampen uit om 22.00 uur
blocks['lampen_2200'] = {}
blocks['lampen_2200']['title'] = 'Lampen uit om 22.00';
blocks['lampen_2200']['width'] = 6;
blocks['lampen_2200']['hide_data'] = true;
//Rolluiken
// Title Luikensets
blocks[title_luikensets] = {}
blocks[title_luikensets]['type'] = 'blocktitle'
blocks[title_luikensets]['title'] = 'Luikensets'
// Luikenset - Waterzijde
blocks['luiken_waterzijde'] = {}
blocks['luiken_waterzijde']['title'] = 'Waterzijde';
blocks['luiken_waterzijde']['width'] = 6;
blocks['luiken_waterzijde']['hide_data'] = true;
// Luikenset - Tuinzijde
blocks['luiken_tuinzijde'] = {}
blocks['luiken_tuinzijde']['title'] = 'Tuinzijde';
blocks['luiken_tuinzijde']['width'] = 6;
blocks['luiken_tuinzijde']['hide_data'] = true;
// Luikenset - Hobby
blocks['luiken_hobby'] = {}
blocks['luiken_hobby']['title'] = 'Hobby';
blocks['luiken_hobby']['width'] = 6;
blocks['luiken_hobby']['hide_data'] = true;
// Title Luiken
blocks[title_luiken] = {}
blocks[title_luiken]['type'] = 'blocktitle'
blocks[title_luiken]['title'] = 'Luiken'
// Luiken - Secretaire
blocks[luik_secretaire] = {}
blocks[luik_secretaire]['width'] = 4;
blocks[luik_secretaire]['title'] = 'Secretaire'
blocks[luik_secretaire]['protected'] = false;
// Luiken - Eettafel
blocks[luik_eettafel] = {}
blocks[luik_eettafel]['width'] = 4;
blocks[luik_eettafel]['title'] = 'Eettafel'
blocks[luik_eettafel]['protected'] = false;
// Luiken - Tuin Raam
blocks[luik_tuinraam] = {}
blocks[luik_tuinraam]['width'] = 4;
blocks[luik_tuinraam]['title'] = 'Tuinraam'
blocks[luik_tuinraam]['protected'] = false;
// Luiken - Tuin Deur
blocks[luik_tuindeur] = {}
blocks[luik_tuindeur]['width'] = 4;
blocks[luik_tuindeur]['title'] = 'Tuindeur'
blocks[luik_tuindeur]['protected'] = false;
// Luiken - Kop Tuin
blocks[luik_kop_tuin] = {}
blocks[luik_kop_tuin]['width'] = 4;
blocks[luik_kop_tuin]['title'] = 'Kop Tuin'
blocks[luik_kop_tuin]['protected'] = false;
// Luiken - Haard
blocks[luik_haard] = {}
blocks[luik_haard]['width'] = 4;
blocks[luik_haard]['title'] = 'Haard'
blocks[luik_haard]['protected'] = false;
// Luiken - Dressoir
blocks[luik_dressoir] = {}
blocks[luik_dressoir]['width'] = 4;
blocks[luik_dressoir]['title'] = 'Dressoir'
blocks[luik_dressoir]['protected'] = false;
// Luiken - Keuken
blocks[luik_keuken] = {}
blocks[luik_keuken]['width'] = 4;
blocks[luik_keuken]['title'] = 'Keuken'
blocks[luik_keuken]['protected'] = false;
// Luiken - Hobby Waterzijde
blocks[luik_hobby_waterzijde] = {}
blocks[luik_hobby_waterzijde]['width'] = 4;
blocks[luik_hobby_waterzijde]['title'] = 'Hobby W'
blocks[luik_hobby_waterzijde]['protected'] = false;
// Luiken - Hobby Kop
blocks[luik_hobby_kop] = {}
blocks[luik_hobby_kop]['width'] = 4;
blocks[luik_hobby_kop]['title'] = 'Hobby K'
blocks[luik_hobby_kop]['protected'] = false;
// Columns
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, theaterspot, title_dimmers, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuinzijde, luiken_waterzijde, luiken_hobby, lampen_2200, title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [title_gas_en_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal, grafiek_gas, gas]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [title_klimaatsensors, regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter, title_deurbel, deurbel, title_rookmelders, rookmelder_gang, title_vochtsensors, vochtsensor_ontvochtiger, vochtsensor_cv_ketel, vochtsensor_waterontharder, vochtsensor_wasmachine]
columns[3]['width'] = 3;
//columns[4] = {}
//columns[4]['blocks'] = [title_overige_schakelaars]
//columns[4]['width'] = 12;
// Screens
var screens = {}
// Desktop
screens[max_resolution_desktop] = {}
screens[max_resolution_desktop]['maxwidth'] = 1920;
screens[max_resolution_desktop]['maxheight'] = 1200;
screens[max_resolution_desktop][1] = {}
screens[max_resolution_desktop][1]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][1]['columns'] = [1,2,3]
//screens[max_resolution_desktop][2] = {}
//screens[max_resolution_desktop][2]['background'] = 'img/bg15.jpg';
//screens[max_resolution_desktop][2]['columns'] = [4]
// Tablet
screens[max_resolution_smart] = {}
screens[max_resolution_smart]['maxwidth'] = 1440;
screens[max_resolution_smart]['maxheight'] = 900;
screens[max_resolution_smart][1] = {}
screens[max_resolution_smart][1]['background'] = 'img/bg.jpg';
screens[max_resolution_smart][1]['columns'] = [1,2,3]
TIA
Greetz,
Sjonnie
