hello domotic friends,
i have a question:
i have my domoticz running on a raspberry in combination with a rooted toon2 an intergas hre 28. with my previous boiler i got in and out of the boiler nicely. with this boiler I don't have any values. the script gives no errors.
my question: is it possible to read the boiler values of this boiler in home automation?
I want to investigate the possibility of controlling the pump of the floor heating with the delta t of the water.
Kind regards: Anne
boiler values in domotic Topic is solved
annesdomotic
- Domoticz version: 4.9700
* raspberry pi3b+
* rooted toon 2
* rooted toon 2
- Eddiever
- Domoticz version: 2022.1
Re: boiler values in domotic
Every Intergas HRE boiler has an OpenTherm connection. But you still need a gateway to get the data. You could build it yourself but you can also buy one (it's named Incomfort Gateway). Buying is, ofcourse, more expensive.
The gateway doesn't need to be very close to the boiler.
Connecting/using the boiler with domoticz, follow the thread below:
https://www.domoticz.com/forum/viewtopi ... =38&t=7745
annesdomotic
