boiler values ​​in domotic Topic is solved
annesdomotic
Domoticz version: 4.9700
Post by annesdomotic »
hello domotic friends,
i have a question:
i have my domoticz running on a raspberry in combination with a rooted toon2 an intergas hre 28. with my previous boiler i got in and out of the boiler nicely. with this boiler I don't have any values. the script gives no errors.
my question: is it possible to read the boiler values ​​of this boiler in home automation?
I want to investigate the possibility of controlling the pump of the floor heating with the delta t of the water.
Kind regards: Anne
* raspberry pi3b+
* rooted toon 2
Eddiever
Domoticz version: 2022.1
Re: boiler values ​​in domotic
Post by Eddiever »
Every Intergas HRE boiler has an OpenTherm connection. But you still need a gateway to get the data. You could build it yourself but you can also buy one (it's named Incomfort Gateway). Buying is, ofcourse, more expensive.
The gateway doesn't need to be very close to the boiler.
Connecting/using the boiler with domoticz, follow the thread below:
https://www.domoticz.com/forum/viewtopi ... =38&t=7745
annesdomotic
thanks for your response
* raspberry pi3b+
* rooted toon 2
