is there a way to get google home to tell me when the diswasher i finished?
tjabas
as the topic says, is there away for google home to tell me when, lets say the washing mashine is finished, or when someone is ringing on the front door?
DutchHans
Re: is there a way to get google home to tell me when the diswasher i finished?
Yes, you can...
You can measure the energy used by the appliance, write a script that sends a message to your phone or let google speak it out loud.. I don't know about your scripting experience or hardware setup.. I could help you if you need help.
Cheers,Hans
Cheers,Hans
Sherlock
- Domoticz version: 4.10717
Hi tjabas,
Take a look at my post ‘Long delay on Google Home voice notifications’.
I have succeeded to receive a spoken notification once the doorbell is pressed.
Only problem is that the time between pressing and the notification is about 7 secs.
Not a problem in case of a connected dishwasher but not very effective in case of the doorbell.
The node-red flow I use is included.
tjabas
Sounds very interesting, do i need to use node red for the voice dotification?Sherlock wrote: Saturday 21 December 2019 20:44 Hi tjabas,
I dot use node red for now.
Sherlock
I suppose there are more ways that lead to Rome.
This is the way I am using.
I have a raspberry with Domoticz installed. I am using RfxTrx433E to connect my sensors to Domoticz (for instance the doorbell). Node-Red is installed on the same RasPi.
The node-red flow ‘node-red-contrib-cast’ is used to connect to the Google Home mini.
Domoticzi is using mqtt to connect to node-red.
tjabas
ok, thank you , i will look into that,thanks
tjabas
Hello again,
so i have been loooking at some youtube videos about node red,it seems a bit fuzzy to get it all working.
so of what i understand, i need to install node red, i will do that on the same raspberry as i run domoticz .
and after that i need to install a mqtt software, but where do i find that, and is there more than one version of it?
is there any more software that i need to install to get it working?
thanks in advance
thanks in advance
Sherlock
Hi tjabas,
Yes basically that is it. Take a look at the Domoticz wiki - mqtt topic.
It takes some effort to get it all installed properly.
So don’t forget to make a backup of your Pi in advance.
After you have installed node-red you can import my flow in node-red.
Good luck.
Good luck.
