is there a way to get google home to tell me when the diswasher i finished?
as the topic says, is there away for google home to tell me when, lets say the washing mashine is finished, or when someone is ringing on the front door?
Re: is there a way to get google home to tell me when the diswasher i finished?
Yes, you can...
You can measure the energy used by the appliance, write a script that sends a message to your phone or let google speak it out loud.. I don't know about your scripting experience or hardware setup.. I could help you if you need help.
Cheers,Hans
Cheers,Hans
- Domoticz version: 4.10717
Hi tjabas,
Take a look at my post ‘Long delay on Google Home voice notifications’.
I have succeeded to receive a spoken notification once the doorbell is pressed.
Only problem is that the time between pressing and the notification is about 7 secs.
Not a problem in case of a connected dishwasher but not very effective in case of the doorbell.
The node-red flow I use is included.
Sounds very interesting, do i need to use node red for the voice dotification?Sherlock wrote: ↑Saturday 21 December 2019 20:44 Hi tjabas,
I dot use node red for now.
I suppose there are more ways that lead to Rome.
This is the way I am using.
I have a raspberry with Domoticz installed. I am using RfxTrx433E to connect my sensors to Domoticz (for instance the doorbell). Node-Red is installed on the same RasPi.
The node-red flow ‘node-red-contrib-cast’ is used to connect to the Google Home mini.
Domoticzi is using mqtt to connect to node-red.
ok, thank you , i will look into that,thanks
Hello again,
so i have been loooking at some youtube videos about node red,it seems a bit fuzzy to get it all working.
so of what i understand, i need to install node red, i will do that on the same raspberry as i run domoticz .
and after that i need to install a mqtt software, but where do i find that, and is there more than one version of it?
is there any more software that i need to install to get it working?
thanks in advance
thanks in advance
Hi tjabas,
Yes basically that is it. Take a look at the Domoticz wiki - mqtt topic.
It takes some effort to get it all installed properly.
So don’t forget to make a backup of your Pi in advance.
After you have installed node-red you can import my flow in node-red.
Good luck.
Good luck.
