Update a dummy temp sensor using DomoticzEvents
froglock30
I wrote a python Time script to manage my boiler.
I am able to read my dummy temp sensor using : DomoticzEvents.Devices["My device"].n_value_string
But I am not able to write into this device
DomoticzEvents.Devices["My device"].n_value_string = 22.5 does nothing.
I am able to manage dummy switch on/off using DomoticzEvents.Command("MySwitch", "Off") and would like to know how to do the same for my temp dummy devices.
Thanks.
Thanks.
peerkersezuuker
Re: Update a dummy temp sensor using DomoticzEvents
I have a similar question.
From the python events module I can toggle switches On/Off with the DomoticzEvents.Command call, but I would like to set a dimmer to a specific level.
For now I am calling the JSON api : ("http://" + domoticzserver + "/json.htm?type=command¶m=switchlight&idx=" + idx_schuifpui + "&switchcmd=Set Level&level=" + mid_level)
But I rather would like to set the level with a native attribute from the DomoticzEvents module.
Peer
Peer
pretty old question, but still no answer. How can we set a value to a setpoint device while using the DomoticzEvents in python ?
- waaren
Hardly know anything from python plugins but have you tried something as setSetPoint ?pipiche wrote: Tuesday 06 October 2020 14:46 pretty old question, but still no answer. How can we set a value to a setpoint device while using the DomoticzEvents in python ?
In Lua it is
commandArray['SetSetPoint:MySetPointIdx']='20.5'Code: Select all
/json.htm?type=command¶m=setsetpoint&idx=&setpoint=Debian buster, bullseye on RPI-4, Intel NUC.
Thanks , I found it while looking into the EventSystem source codewaaren wrote: Tuesday 06 October 2020 16:29Hardly know anything from python plugins but have you tried something as setSetPoint ?pipiche wrote: Tuesday 06 October 2020 14:46 pretty old question, but still no answer. How can we set a value to a setpoint device while using the DomoticzEvents in python ?
In Lua it isthe APICode: Select all
I'm trying to update a user variables with the following syntax but it seems that there no change happening.
What am I doing wrong ?
import DomoticzEvents as Dz
Dz.user_variables[ 'my variable' ] = "22"
- waaren
Lua does usepipiche wrote: Wednesday 07 October 2020 18:45 I'm trying to update a user variables with the following syntax but it seems that there no change happening.
commandArray['Variable:MyVar']='Some value'
so it could be something along the same line. But if you read the template Python template script in the event editor, setting a uservariable is one of things on the TODO list and so likely not implemented yet (same is true for the wiki (also on the todo list) )
thanks @waaren
bobbytux
Looking at the sources, I found that for python :
DE.Command( 'CustomCommand:' + idx, doWhat) # I don't know how to use it and it's usage ..
DE.Command( 'SetSetpoint:' + idx, 'val1#val2#val3') # I don't know how to use it and it's usage ..
DE.Command( 'Variable:' + variable_name, value_to_affect) # OK, this one works fine
No implémentation of UpdateDevice
I have gone into the same problem (I have a Eurotronic Spirit thermostatic valve).
Thanks to this thread and some other research and experimentation, I have found that:
The other possibilities seen in source code of DomoticzEvents module (eg. "CustomCommand") remain unknown to me (some need to go far in the code to understand what they do), and I even don't understand really how the "SetSetpoint" command does what it does (which is what I want).
There is also a DE.Devices.update() method, no idea how/what it does.
I still need to find a way to configure the "mode" of my valve (I can set it to "Heat" for maximum heating, "Eco", for lower temperature, "OFF", etc.)
DE.Command('Variable:Foo', '14') # Sets User Variable "Foo" to value 14
DE.Command('SetSetpoing:123', '20') # Sets the Setpoint device of my valve to 20 (123 is the ID of the device)
DE.Command('Heater relay', 'On') # Sets my heater (name "Heater relay") to ONThere is also a DE.Devices.update() method, no idea how/what it does.
