Update a dummy temp sensor using DomoticzEvents
froglock30
Post by froglock30 »
I wrote a python Time script to manage my boiler.
I am able to read my dummy temp sensor using : DomoticzEvents.Devices["My device"].n_value_string
But I am not able to write into this device
DomoticzEvents.Devices["My device"].n_value_string = 22.5 does nothing.
I am able to manage dummy switch on/off using DomoticzEvents.Command("MySwitch", "Off") and would like to know how to do the same for my temp dummy devices.
Thanks.
peerkersezuuker
Re: Update a dummy temp sensor using DomoticzEvents
Post by peerkersezuuker »
I have a similar question.
From the python events module I can toggle switches On/Off with the DomoticzEvents.Command call, but I would like to set a dimmer to a specific level.
For now I am calling the JSON api : ("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + idx_schuifpui + "&switchcmd=Set Level&level=" + mid_level)
But I rather would like to set the level with a native attribute from the DomoticzEvents module.
Peer
pipiche
Post by pipiche »
pretty old question, but still no answer. How can we set a value to a setpoint device while using the DomoticzEvents in python ?
pipiche wrote: Tuesday 06 October 2020 14:46 pretty old question, but still no answer. How can we set a value to a setpoint device while using the DomoticzEvents in python ?
Hardly know anything from python plugins but have you tried something as setSetPoint ?
In Lua it is
commandArray['SetSetPoint:MySetPointIdx']='20.5'
the API
/json.htm?type=command&param=setsetpoint&idx=&setpoint=
pipiche
Post by pipiche »
waaren wrote: Tuesday 06 October 2020 16:29
In Lua it is
the API
Thanks , I found it while looking into the EventSystem source code ;-)
pipiche
Post by pipiche »
I'm trying to update a user variables with the following syntax but it seems that there no change happening.
What am I doing wrong ?
import DomoticzEvents as Dz
Dz.user_variables[ 'my variable' ] = "22"
pipiche wrote: Wednesday 07 October 2020 18:45 I'm trying to update a user variables with the following syntax but it seems that there no change happening.
Lua does use
commandArray['Variable:MyVar']='Some value'
so it could be something along the same line. But if you read the template Python template script in the event editor, setting a uservariable is one of things on the TODO list and so likely not implemented yet (same is true for the wiki (also on the todo list) )
pipiche
Post by pipiche »
thanks @waaren
bobbytux
Post by bobbytux »
Looking at the sources, I found that for python :
DE.Command( 'CustomCommand:' + idx, doWhat) # I don't know how to use it and it's usage ..
DE.Command( 'SetSetpoint:' + idx, 'val1#val2#val3') # I don't know how to use it and it's usage ..
DE.Command( 'Variable:' + variable_name, value_to_affect) # OK, this one works fine ;)
No implémentation of UpdateDevice :(
Regards :)
Deltree
Post by Deltree »
I have gone into the same problem (I have a Eurotronic Spirit thermostatic valve).
Thanks to this thread and some other research and experimentation, I have found that:
DE.Command('Variable:Foo', '14') # Sets User Variable "Foo" to value 14
DE.Command('SetSetpoing:123', '20') # Sets the Setpoint device of my valve to 20 (123 is the ID of the device)
DE.Command('Heater relay', 'On') # Sets my heater (name "Heater relay") to ON
The other possibilities seen in source code of DomoticzEvents module (eg. "CustomCommand") remain unknown to me (some need to go far in the code to understand what they do), and I even don't understand really how the "SetSetpoint" command does what it does (which is what I want).
There is also a DE.Devices.update() method, no idea how/what it does.
I still need to find a way to configure the "mode" of my valve (I can set it to "Heat" for maximum heating, "Eco", for lower temperature, "OFF", etc.)
