Compatible airconditioning systems
Egregius
Domoticz version: v2024.7
Post by Egregius »
I'm in search to install several airconditioning units in my home, one in each room.
Ofcourse they need to get integrated in my Domoticz / Pass2php system so I can control them.
On the hardware page I only find 1: "Daikin Airconditioning with LAN HTTP interface". Can't be that Daikin is the only one having a good API I guess.
Therefore this topic, which brands have this? This will be one of the first things I look at to choose a brand. I don't want the same story as with my Bosh Easycontrol thermostat where a API is promised but isn't there 2 years later.
Things I'd like to control, in order of importance:
- On/Off
- Setpoint for each wall unit
- Fan speed
- Heating/Cooling mode
2 vendors made a visit at my home (Samsung, Fujitsu), but if I talk about this it's like they hear the thunder in Cologne...
Thanks for your ideas on this ;)
DutchSolar
Domoticz version: 4.9700
Re: Compatible airconditioning systems
Post by DutchSolar »
Hey,
I was also going to ask a couple of companies to give me a quote. I need 4 or 5 indoor units and preferably 1 outdoor unit.
I would also like to be able to control them through Domoticz, have you found any new info regarding this? Did you choose a system yet?
FireWizard
Post by FireWizard »
Do not only focus on a brand, which is mentioned in the Domoticz hardware list.
Other things, such as specs, look and price is probably more important.
If an API or even a script is available that collects the data you want to see in Domoticz, you can consider that as an extra advantage.
Currently we are configuring a Panasonic device to communicate with Domoticz.
You are invited to read the post at: https://www.domoticz.com/forum/index.php
Egregius
Post by Egregius »
I whent for a Daikin multi-split with 3 indoor units. They had great specs, good price and API.
