How to run a python3 script from a dzVents script ?  [Solved]
MMSoft
Post by MMSoft »
Is it possible to run a python3 script from a dzVents script ?
And if so how is that exactly?
This does not work:
shellCommand = "python3 /home/pi/domoticz/scripts/python/Test.py"
sys.executable('python3 /home/pi/domoticz/scripts/python/Test.py')
os.system('python3 /home/pi/domoticz/scripts/python/Test.py')
felix63
Domoticz version: 2020.1
Re: How to run a python3 script from a dzVents script ?
Post by felix63 »
Try using
domoticz.osExecute("python3 /home/pi/domoticz/scripts/python/Test.py")
Function: Execute an os command.
MMSoft
Post by MMSoft »
Thanks for your reply.
Unfortunately, this gives the error message: attempt to call field 'osExecute' (a nil value)
MMSoft wrote: Thursday 28 November 2019 10:50 Thanks for your reply.
The command in dzVents is domoticz.utils.osExecute("python3 /home/pi/domoticz/scripts/python/Test.py") but you can also use
os.execute("python3 /home/pi/domoticz/scripts/python/Test.py")
MMSoft
Re: How to run a python3 script from a dzVents script ?  [Solved]
Post by MMSoft »
Thanks !!!
MMSoft wrote: Friday 29 November 2019 10:40Thanks !!!
My personal preference for executing OS commands / scripts in dzVents is the following function.
It has a better error handling than osExecute and returns output (if any) and OS returnCode
        local function osCommand(cmd)
            if dz == nil then dz = domoticz end -- make sure dz is declared as domoticz object if not already done earlier
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
               dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
            else -- all is fine!!
                dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
Codec303
Post by Codec303 »
Hi, where would I need to add this code in order to use it in my script? Thanks
waaren wrote: Friday 29 November 2019 11:02
Codec303 wrote: Tuesday 17 December 2019 18:05 Hi, where would I need to add this code in order to use it in my script? Thanks
In the execute = section
Can be any place as long as it is above the call to this function.
See example below
return
    on =
        timer = { 'every minute' }
    execute = function(dz)
        local result, rc = osCommand('ls -l')
        dz.log('return Code: ' .. rc  ,dz.LOG_FORCE)
        dz.log('Result: \n' .. result,dz.LOG_FORCE)
