Is it possible to run a python3 script from a dzVents script ?
And if so how is that exactly?
This does not work:
shellCommand = "python3 /home/pi/domoticz/scripts/python/Test.py"
sys.executable('python3 /home/pi/domoticz/scripts/python/Test.py')
os.system('python3 /home/pi/domoticz/scripts/python/Test.py')
How to run a python3 script from a dzVents script ? [Solved]
- felix63
- Domoticz version: 2020.1
Re: How to run a python3 script from a dzVents script ?
Try usingFunction: Execute an os command.
domoticz.osExecute("python3 /home/pi/domoticz/scripts/python/Test.py")Re: How to run a python3 script from a dzVents script ?
Thanks for your reply.
Unfortunately, this gives the error message: attempt to call field 'osExecute' (a nil value)
- waaren
The command in dzVents is domoticz.utils.osExecute("python3 /home/pi/domoticz/scripts/python/Test.py") but you can also useMMSoft wrote: Thursday 28 November 2019 10:50 Thanks for your reply.
os.execute("python3 /home/pi/domoticz/scripts/python/Test.py")
- waaren
My personal preference for executing OS commands / scripts in dzVents is the following function.
It has a better error handling than osExecute and returns output (if any) and OS returnCode
local function osCommand(cmd)
if dz == nil then dz = domoticz end -- make sure dz is declared as domoticz object if not already done earlier
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
Codec303
Hi, where would I need to add this code in order to use it in my script? Thanks
- waaren
In the execute = sectionCodec303 wrote: Tuesday 17 December 2019 18:05 Hi, where would I need to add this code in order to use it in my script? Thanks
Can be any place as long as it is above the call to this function.
See example below
return
on =
timer = { 'every minute' }
execute = function(dz)
local result, rc = osCommand('ls -l')
dz.log('return Code: ' .. rc ,dz.LOG_FORCE)
dz.log('Result: \n' .. result,dz.LOG_FORCE)
}Debian buster, bullseye on RPI-4, Intel NUC.
