can't choose another img in block
Dave47
Domoticz version: 2023.1
Post by Dave47 »
Hallo I have block 276 for thermostat settings.
By default there is an img file img/heating.png
I can't change it for this block
blocks["'276']['image'] = '../img/example.png';
blocks["'276']['image'] = 'example.png';
blocks['276'] = {}
blocks['276']['width'] = 6;
blocks['276']['title'] = 'Instelling';
Is it not possible because this is a thermostat?
Lokonli
Re: can't choose another img in block
Post by Lokonli »
Dave47 wrote: Wednesday 30 October 2019 11:06 Hallo I have block 276 for thermostat settings.
blocks['276'] = {}
Correct. Currently the image for a thermostat device is fixed.
I was improving this already for some special blocks. As a next step I'll look into the domoticz devices.
Dave47
Post by Dave47 »
Ok. Thank you
Lokonli
Post by Lokonli »
Lokonli wrote: Wednesday 30 October 2019 12:43
blocks['276'] = {}
It seems it's already possible to change the image or icon for a thermostat block.
@Dave47:
Can you test by adding the following to your CONFIG.js:
	blocks['276_2'] = {
		image: 'example.png'
flemm
Domoticz version: 4.11780
Post by flemm »
Hi! I've just started with domoticz & dashticz about a week ago, and really like it.
Sorry to bump this. I've been trying for days to figure out a way to change the heating.png image to an icon, without success. So i was glad that i found this thread.
I've tried changing it to an other image file as suggested, but that doesn't seem to work.
Has there been any progress with this feature? Or might there be some sort of workaround to override the default image for this block?
Mario ipsum RGB mushroom 1-up.
Lokonli
Post by Lokonli »
What is the device type for which you want to change the image? Also the thermostat device?
flemm
Post by flemm »
Yes, the image for my Nest, with class .iconheating, which is set to heating.png..
Lokonli
Post by Lokonli »
It should be implemented in latest beta, at least for a generic thermostat device. Can you check with your Nest?
flemm
Post by flemm »
Lokonli wrote: Friday 10 April 2020 17:48 It should be implemented in latest beta, at least for a generic thermostat device. Can you check with your Nest?
Sorry, i've been busy with other things than my dashboard lately, so my reply is a little late. Still use my dash daily though, and yes, it works like a charm. Thanks for implementhing the fix!
Screenshot 2020-05-13 at 16.17.29.png (31.99 KiB) Viewed 730 times
Lokonli
Post by Lokonli »
Thanks for the feedback!
