problem with some lua scripts.
sjoemie1985
Post by sjoemie1985 »
i also posted this in an other topic, but when i saw that that topic was solved is made an new topic with my problem so here it is. :)
Good morning,
i have some problems with uploading the right data to pvoutput.org the enrgy used and power Used are continues on 0 in stead of data.
so what am is doing wrong?
i am using the following 2 scripts.
i have also the sems portal plugin in my domoticz.
Device Calculation script.
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- This script collects the values below from Domoticz
--   * The Power and energy values (import and export) from a smartmeter
--   * The Power and energy values from a Solar power inverter
-- It then calculates the consumed power and energy from the values above with the formula's
--   * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
--   * PowerConsumption = PowerGeneration + PowerImport - PowerExport
-- It then updates a virtual device which displays the consumed power and energy in Domoticz
-- Domoticz IDX and names of the needed devices
local GenerationDeviceName = "CurrentOutput" 		-- Device name of the Generated energy
local EnergyDeviceName = "Power" 		-- Name of the energy device that shows imported and exported energy
local ConsumptionIDX = 31  			-- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "ConsumptionDevice" 		-- Name of the energy device that shows calculated Consumption
-- Require parameters
local http = require("socket.http")
-- Script parameters
EnergyImportLow = 0	-- in Watt hours
EnergyImportHigh = 0	-- in Watt hours
EnergyExportLow = 0	-- in Watt hours
EnergyExportHigh = 0	-- in Watt hours
EnergyGeneration = 0 	-- in Watt hours
PowerGeneration = 0 	-- in Watts
EnergyImport = 0	-- in Watt hours
PowerImport = 0		-- in Watts
EnergyConsumption = 0 	-- in Watt hours
PowerConsumption = 0 	-- in Watts
Debug = "YES" 		-- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
	commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
	-- Generated
	PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
	if Debug=="YES" then
		print("  ----- PowerGeneration = " .. PowerGeneration .. " W");
		print("  ----- EnergyGeneration = " .. EnergyGeneration .. " Wh");
	EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[EnergyDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
	EnergyImport = EnergyImportLow + EnergyImportHigh
	EnergyExport = EnergyExportLow + EnergyExportHigh
		print("  ----- PowerImport = " .. PowerImport .. " W");
		print("  ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
		print("  ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
		print("  ----- EnergyImport = " .. EnergyImport .. " Wh");
		print("  ----- PowerExport = " .. PowerExport .. " W");
		print("  ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
		print("  ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
		print("  ----- EnergyExport = " .. EnergyExport .. " Wh");
	-- Calculate consumption
		print("  ----- PowerConsumption = " .. PowerConsumption .. " W");
		print("  ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
	-- Update comsumption device in Domoticz
	if devicechanged[EnergyDeviceName] then
		update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
TIME SCRIPT
-- /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua
--   * The Power generation, energy generation and voltage from a Solar power inverter
--   * The temperature from a outside temperature sensor
--   * The Power consumption and energy consumption which is calculated in another Lua script
-- And uploads all of the values to a PVoutput account.
-- For more information about PVoutput, see their user documentation on http://www.pvoutput.org/help.html
-- Domoticz IDX of devices
local GenerationDeviceName = "PowerOutput"	-- Device name of the Generated energy
local VoltageDeviceName = "VoltageOutput"	-- Name of the voltage device that shows voltage of the inverter
local TemperatureDeviceName = "Temperatuur" -- Name of the temperature device that shows outside temperature
-- PVoutput parameters
local PVoutputApi = "c550e7568ba649922fd015828f********"		-- Your PVoutput api key
local PVoutputSystemID = "699" 					-- Your PVoutput System ID
local PVoutputPostInterval = 5  					-- The number of minutes between posts to PVoutput (normal is 5 but when in donation mode it's max 1)
local PVoutputURL = '://pvoutput.org/service/r2/addstatus.jsp?key='	-- The URL to the PVoutput Service
EnergyGeneration = 0 	-- v1 in Watt hours
PowerGeneration = 0 	-- v2 in Watts
EnergyConsumption = 0 	-- v3 in Watt hours
PowerConsumption = 0 	-- v4 in Watts
CurrentTemp = 0 	-- v5 in celcius
Voltage = 0 		-- v6 in volts
c1 = 1 			-- c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
-- Lua Functions
function UploadToPVoutput(self)
	b, c, h = http.request("http" .. PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M") ..
	"&v1=" .. EnergyGeneration .. "&v2=" .. PowerGeneration .. "&v3=" .. EnergyConsumption .. "&v4=" .. PowerConsumption .. "&v5=" .. CurrentTemp .. "&v6=" .. Voltage .. "&c1=" .. c1 )
	if b=="OK 200: Added Status" then
		print(" -- Current status successfully uploaded to PVoutput.org")
		print(" -- " ..b)
	print("  --Energy generation (v1) = ".. EnergyGeneration .. " Wh")
	print("  --Power generation (v2) = " .. PowerGeneration .. " W")
	print("  --Energy consumption (v3) = " .. EnergyConsumption .. " Wh")
	print("  --Power consumption (v4) = " .. PowerConsumption .. " W")
	print("  --Current temperature (v5) = " .. CurrentTemp .. " C")
	print("  --Voltage (v6) = " .. Voltage .. "V")
	print("  --Cumulative Flag (c1) = " .. c1 .. "")
-- CommandArray
	time = os.date("*t")
	if PVoutputPostInterval > 1 then
		TimeToGo = PVoutputPostInterval - (time.min % PVoutputPostInterval)
		print('Time to go before upload to PVoutput: ' ..TimeToGo.. " minutes")
	if((time.min % PVoutputPostInterval)==0)then
		-- Generated
			print(" ---- The total generated energy is " .. EnergyGeneration .. " Wh");
			print(" ---- The current generated power is " .. PowerGeneration .. " W");
		-- Voltage
		Voltage = otherdevices_svalues[VoltageDeviceName] :match("([^;]+)")
			print(" ---- The voltage of the inverter is " .. Voltage .. " V");
		-- Temperature
		CurrentTemp = otherdevices_svalues[TemperatureDeviceName]:match("([^;]+)")
			print(" ---- The outside temperature is " .. CurrentTemp .. " C.");
		--EnergyGeneration = "0"
		--PowerGeneration = "0"
		-- Consumption
		EnergyConsumption, PowerConsumption = otherdevices_svalues[ConsumptionDeviceName]:match("([^;]+);([^;]+)")
			print(" ---- The total consumed energy is " .. EnergyConsumption .. " Wh");
			print(" ---- The current consumed power is " .. PowerConsumption .. " W");
		-- Upload data to PVoutput
		UploadToPVoutput()
I get also the following error in domoticz log
...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
2019-09-26 10:39:45.976 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
2019-09-26 10:39:45.995 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
i also think something is wrong with the energy import high and low.
because the low is higher than the importhigh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyGeneration = 339500.0 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- PowerImport = 64 W
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImportLow = 51778 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImportHigh = 26840 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImport = 78618 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- PowerExport = 0 W
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyExportLow = 39607 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyExportHigh = 75129 Wh
so what script do i have to use to get the right data to pvoutput.org and what am i doing wrong?
sjoemie1985
Re: problem with some lua scripts.
i think i have the sollution.
i placed in my device calculation script 2 times the device name from my P1 meter from domoticz and than i saw information in the dummy don't know if that is okay?
i can't find wich device should be filled in on the xxxxx from these lua scripts.
because i thougt that the generation device name should be my solar panels?
and the energy devicename the name off my P1 power?
the usage i think is the energy that i use from the power net provider?
and delivery is what my solar panels are delivering to the power net?
Thorgal789
Post by Thorgal789 »
line 71 > PowerConsumption = PowerGeneration + PowerImport - PowerExport
Print all value in domoticz logs to check wich one is not an integer, you will find the guilty.
for me it's PowerGeneration, so the problem is from
Perhaps your device "GenerationDeviceName" have not date in good format.
Print the value of PowerGeneration, just after this line, I m sure you haven't an integer value.
sjoemie1985
Thorgal789 wrote: Thursday 03 October 2019 21:26
what device is my generation device?
Should that be a device from my solar panels from out of domoticz?
Thorgal789
According to the code value are
GenerationDeviceName is something with POWER;ENERGY
EnergyDeviceName is something on the form x;x;x;x;x;x
ConsumptionIDX is something on the form POWER;ENERGY
ConsumptionDeviceName something like POWER;ENERGY
So on my side I will try
GenerationDeviceName > PowerOutput
EnergyDeviceName > Power
ConsumptionIDX > 31
ConsumptionDeviceName > ConsumptionDevice
