Good morning,
i have some problems with uploading the right data to pvoutput.org the enrgy used and power Used are continues on 0 in stead of data.
so what am is doing wrong?
i am using the following 2 scripts.
i have also the sems portal plugin in my domoticz.
Device Calculation script.
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- This script collects the values below from Domoticz
-- * The Power and energy values (import and export) from a smartmeter
-- * The Power and energy values from a Solar power inverter
-- It then calculates the consumed power and energy from the values above with the formula's
-- * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
-- * PowerConsumption = PowerGeneration + PowerImport - PowerExport
-- It then updates a virtual device which displays the consumed power and energy in Domoticz
-- Domoticz IDX and names of the needed devices
local GenerationDeviceName = "CurrentOutput" -- Device name of the Generated energy
local EnergyDeviceName = "Power" -- Name of the energy device that shows imported and exported energy
local ConsumptionIDX = 31 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "ConsumptionDevice" -- Name of the energy device that shows calculated Consumption
-- Require parameters
local http = require("socket.http")
-- Script parameters
EnergyImportLow = 0 -- in Watt hours
EnergyImportHigh = 0 -- in Watt hours
EnergyExportLow = 0 -- in Watt hours
EnergyExportHigh = 0 -- in Watt hours
EnergyGeneration = 0 -- in Watt hours
PowerGeneration = 0 -- in Watts
EnergyImport = 0 -- in Watt hours
PowerImport = 0 -- in Watts
EnergyConsumption = 0 -- in Watt hours
PowerConsumption = 0 -- in Watts
Debug = "YES" -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
-- Generated
PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
if Debug=="YES" then
print(" ----- PowerGeneration = " .. PowerGeneration .. " W");
print(" ----- EnergyGeneration = " .. EnergyGeneration .. " Wh");
EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[EnergyDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
EnergyImport = EnergyImportLow + EnergyImportHigh
EnergyExport = EnergyExportLow + EnergyExportHigh
print(" ----- PowerImport = " .. PowerImport .. " W");
print(" ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
print(" ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
print(" ----- EnergyImport = " .. EnergyImport .. " Wh");
print(" ----- PowerExport = " .. PowerExport .. " W");
print(" ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
print(" ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
print(" ----- EnergyExport = " .. EnergyExport .. " Wh");
-- Calculate consumption
print(" ----- PowerConsumption = " .. PowerConsumption .. " W");
print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
-- Update comsumption device in Domoticz
if devicechanged[EnergyDeviceName] then
update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
TIME SCRIPT
-- /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua
-- * The Power generation, energy generation and voltage from a Solar power inverter
-- * The temperature from a outside temperature sensor
-- * The Power consumption and energy consumption which is calculated in another Lua script
-- And uploads all of the values to a PVoutput account.
-- For more information about PVoutput, see their user documentation on http://www.pvoutput.org/help.html
-- Domoticz IDX of devices
local GenerationDeviceName = "PowerOutput" -- Device name of the Generated energy
local VoltageDeviceName = "VoltageOutput" -- Name of the voltage device that shows voltage of the inverter
local TemperatureDeviceName = "Temperatuur" -- Name of the temperature device that shows outside temperature
-- PVoutput parameters
local PVoutputApi = "c550e7568ba649922fd015828f********" -- Your PVoutput api key
local PVoutputSystemID = "699" -- Your PVoutput System ID
local PVoutputPostInterval = 5 -- The number of minutes between posts to PVoutput (normal is 5 but when in donation mode it's max 1)
local PVoutputURL = '://pvoutput.org/service/r2/addstatus.jsp?key=' -- The URL to the PVoutput Service
EnergyGeneration = 0 -- v1 in Watt hours
PowerGeneration = 0 -- v2 in Watts
EnergyConsumption = 0 -- v3 in Watt hours
PowerConsumption = 0 -- v4 in Watts
CurrentTemp = 0 -- v5 in celcius
Voltage = 0 -- v6 in volts
c1 = 1 -- c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
-- Lua Functions
function UploadToPVoutput(self)
b, c, h = http.request("http" .. PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M") ..
"&v1=" .. EnergyGeneration .. "&v2=" .. PowerGeneration .. "&v3=" .. EnergyConsumption .. "&v4=" .. PowerConsumption .. "&v5=" .. CurrentTemp .. "&v6=" .. Voltage .. "&c1=" .. c1 )
if b=="OK 200: Added Status" then
print(" -- Current status successfully uploaded to PVoutput.org")
print(" -- " ..b)
print(" --Energy generation (v1) = ".. EnergyGeneration .. " Wh")
print(" --Power generation (v2) = " .. PowerGeneration .. " W")
print(" --Energy consumption (v3) = " .. EnergyConsumption .. " Wh")
print(" --Power consumption (v4) = " .. PowerConsumption .. " W")
print(" --Current temperature (v5) = " .. CurrentTemp .. " C")
print(" --Voltage (v6) = " .. Voltage .. "V")
print(" --Cumulative Flag (c1) = " .. c1 .. "")
-- CommandArray
time = os.date("*t")
if PVoutputPostInterval > 1 then
TimeToGo = PVoutputPostInterval - (time.min % PVoutputPostInterval)
print('Time to go before upload to PVoutput: ' ..TimeToGo.. " minutes")
if((time.min % PVoutputPostInterval)==0)then
-- Generated
print(" ---- The total generated energy is " .. EnergyGeneration .. " Wh");
print(" ---- The current generated power is " .. PowerGeneration .. " W");
-- Voltage
Voltage = otherdevices_svalues[VoltageDeviceName] :match("([^;]+)")
print(" ---- The voltage of the inverter is " .. Voltage .. " V");
-- Temperature
CurrentTemp = otherdevices_svalues[TemperatureDeviceName]:match("([^;]+)")
print(" ---- The outside temperature is " .. CurrentTemp .. " C.");
--EnergyGeneration = "0"
--PowerGeneration = "0"
-- Consumption
EnergyConsumption, PowerConsumption = otherdevices_svalues[ConsumptionDeviceName]:match("([^;]+);([^;]+)")
print(" ---- The total consumed energy is " .. EnergyConsumption .. " Wh");
print(" ---- The current consumed power is " .. PowerConsumption .. " W");
-- Upload data to PVoutput
UploadToPVoutput()
...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
2019-09-26 10:39:45.976 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
2019-09-26 10:39:45.995 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:71: attempt to perform arithmetic on global 'PowerGeneration' (a string value)
i also think something is wrong with the energy import high and low.
because the low is higher than the importhigh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyGeneration = 339500.0 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- PowerImport = 64 W
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImportLow = 51778 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImportHigh = 26840 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyImport = 78618 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- PowerExport = 0 W
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyExportLow = 39607 Wh
2019-09-26 10:44:18.992 Status: LUA: ----- EnergyExportHigh = 75129 Wh
so what script do i have to use to get the right data to pvoutput.org and what am i doing wrong?
