I was looking at my power consumption and saw a very high usage. Seems like the counter got reset and therefor gave me a very high usage.
Is there any way to correct this jump?
Kind regards
Daan
Power meter counter reset
DaanT
- Domoticz version: 2020.2
- graph.PNG (47.91 KiB) Viewed 2809 times
- log.PNG (20.29 KiB) Viewed 2809 times
- FireWizard
Re: Power meter counter reset
Point with your mouse to the value, you want to remove and press the "Shift" + "Left Mouse Key".
That should do the trick.
DaanT
Thank you FireWizard.
Kind regards
DaanT
Kind regards
DaanT
arnaudarduino
I have that to, but when klik on it ,ask me to remove. But is not going away.
Somthing with rights or so?
woodbury1379
- Target OS: OS X
I think so there is something with rightsarnaudarduino wrote: Thursday 26 September 2019 19:24 I have that to, but when klik on it ,ask me to remove McDVOICE
maxim009
Hello, I have same problem - so high consumption after counter reset. I've tried SHIFT+"left/right click", and a lot of another combinations and no action. I've clicked on value row and also in graph and nothing happend. Where should I click? Some special setting? (I think I'm the only one administrator of my Domoticz
). Thanks in advance for some hint.
- Výběr_001.png (90.17 KiB) Viewed 1388 times
- erem
- Domoticz version: 2021.1
you can edit the database directly using sqlite3, or if you are on *nix, use sqlitebrowser.
the table containing the offending entry is multimeter_calender.
- stop domoticz
- reset the value to whatever you want
start domoticz
- stop domoticz
start domoticz
Regards,
Rob
Rob
- Domoticz version: 2025.1
That delete function with Shift-left click is only working in the graphs on device log page and not in the device report page. Your screenshot shows the report page..... https://www.domoticz.com/wiki/Managing_ ... Device_Logmaxim009 wrote: Tuesday 16 March 2021 7:40 Hello, I have same problem - so high consumption after counter reset. I've tried SHIFT+"left/right click", and a lot of another combinations and no action. I've clicked on value row and also in graph and nothing happend. Where should I click? Some special setting? (I think I'm the only one administrator of my Domoticz). Thanks in advance for some hint.
So if you want to remove a really old value, older than 1 year, you have to remove it from the database manually.
maxim009
.. thank you @waltervl - yes, that's it - I was on report page.waltervl wrote: Tuesday 16 March 2021 14:35 That delete function with Shift-left click is only working in the graphs on device log page and not in the device report page. Your screenshot shows the report page..... https://www.domoticz.com/wiki/Managing_ ... Device_Log
.. thank you @erem - I've edited database directly by sqlitebrowser.erem wrote: Tuesday 16 March 2021 13:57 you can edit the database directly using sqlite3, or if you are on *nix, use sqlitebrowser.
- stop domoticz
start domoticz
