220V Floor heating thermostat recommendations
FearNaBoinne
Domoticz version: 2021.1
Post by FearNaBoinne »
I am looking for 220V floor heating thermostats that work with Domoticz (Z-wave, Wifi, Zigbee (hue compatible) or 433MHz (RFlink) are all options) and are affordable.
Requirements:
Provide current temperature value to Domoticz
Provide set target temperature value to Domoticz
Provide on/off state value to Domoticz
Target temperature can be set via Domoticz
Any and all recommendations welcome...
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
Geitje
Re: 220V Floor heating thermostat recommendations
Post by Geitje »
I use Z-Wave Plus HEAT-IT 2 thermostat for some months now. Works flawless. It reports all the values you mention. What some find missing is the room-temperature. It is not reported back, unles you install a small sensor on the thermostat yourself (cheap and easy). I do not miss this so far.
Zwave, Zigate, RFlink etc.
kimot
Domoticz version: v3.8153
Post by kimot »
I am using this over two years:
https://www.youtube.com/watch?v=1ef6tRinOQ4
I only switch from Wemos to Sonoff Basic, due to problems with powering more Wemoses with connected relays through UTP cable bus.
Last version sends room and floor temperature, heating status, power consumption and number of relay actions to Domoticz.
From Domoticz it receives setpoint value, mode of controll (floor, room or off ), HDO status and outdoor temperature, which can be used for equitherm regulation, if needed.
( but not implemented now )
Through setpoint timer is very easy implement weekly temperature timer function.
You can regulate room temperature with checking max allowed floor temperature or regulate floor temperature ( I am using this ).
I plan some display and buttons on thermostat, but I do need changes more often, so I am happy with settings by computer or Android mobile.
I have got double wall box, so sonoff fits easy to it.
Looks like this:
Shelly or Sonoff Mini can fit single wall box if needed.
All works independently from Domoticz.
Domoticz only sends data and receives values, but temperature regulation and max floor temperature control is done by Sonoff itself.
Rules and DZVents script are in discussion bellow video.
Important !!
I am using ESPeasy v2.0, version
Not mega - it handle my rules incorrectly.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
FearNaBoinne
I looked at that YouTube video before... I like the concept, but the WAF *requires* it has buttons and display...
AimoPaukku
Domoticz version: Stable
Post by AimoPaukku »
Any news?
I have a same problem.
