Configuration Neo Coolcam Z wave Door sensor
witteherder
Domoticz version: 4.10717
Post by witteherder »
Hello
Can anyone help me with a manual (website or youtube) how to configure the door sensor AFTER installation in Domoticz.
I want to see when the Door is opened en closed
najtram
Domoticz version: v4.9700
Re: Configuration Neo Coolcam Z wave Door sensor
Post by najtram »
I have experience with other hardware but maybe your question is also answered with this solution:
My hardware provided two switches, one for off and one for on.
For me it worked by creating an extra dummy (door) switch in the hardware part. And after this I created an event. See attached image. By renaming the real switches with a $ before the name, I now only see the result in the one dummy-switch.
Schermafdruk 2019-08-19 14.41.21.png (38.66 KiB) Viewed 1602 times
Schermafdruk 2019-08-19 14.40.43.png (48.91 KiB) Viewed 1602 times
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
witteherder
With me it looks like this in Domoticz
najtram
Post by najtram »
And what happens when you open/close the sensor? Which ID is triggered? I think ID 23?
ZigBee → ConBee II
LAN → Enphase Envoy
witteherder
Yes ID23
najtram
Post by najtram »
I think you want the following:
You could remove all the other sensors, and just add or keep 23. Edit the that sensor in the overview of all switches and change it to Door type.
Not sure if that last part works, because I cannot reproduce your situation.
ZigBee → ConBee II
LAN → Enphase Envoy
witteherder
Like this?
najtram
Post by najtram »
Yes, maybe also another icon. Does that suit your wishes?
ZigBee → ConBee II
LAN → Enphase Envoy
Solderbro
Domoticz version: 2020.1
Post by Solderbro »
Using two of these in basic config here.
1. Configuring the OFF Delay: (second) (aktuell: 0)
2. Basic Set Level: (aktuell: 255)
2000. Wake-up Interval: (Seconds) (aktuell: 43200)
They report an open / close movement through sensor and access control. Domoticz reports a window open until it get closed again.
Until now had no better idea than to warn about harsh climate from on the balcony. Later they should be added in the alarm setup.
Ethan Hunt will break at full hour into a domoticz secured home, because of the hourly backup.....
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
witteherder
Where can I config this?
Especially option 2
1 off delay should be 0 seconds?
2 basic set level should be 2000 seconds?
3. Wake up interval should be how many seconds???
Because i don't see it here?
najtram
Post by najtram »
I'm missing that part of hands-on experience. But I think he is talking about settings in the hardware menu:
Go to: Settings, Hardware, Settings of the Z-wave dongle, In device list select the sensor, and scroll down for the settings.
ZigBee → ConBee II
LAN → Enphase Envoy
