NeoCoolcam PIR V2+ disable LED?
Posted: Sunday 16 June 2019 12:28
by renerene
Allthough zwave setup says it is disabled, my LED still flashes. And is draining my battery.
simular symptoms:
here
Anybody got it fixed?
Re: NeoCoolcam PIR V2+ disable LED?
Posted: Sunday 16 June 2019 13:28
by gizmocuz
Did you press the 'Save Changes' button at the bottom ?
If yes, could you try to select 'Control Panel' from the dropdown, and set the configuration here
What is your domoticz version ?
Posted: Sunday 16 June 2019 22:19
by renerene
Control panel and domoticz both show parameter 10 disabled (led off). Pressed three times fast on the PIR button to wake device.
Older neocam version 1 work flwaless
Driving. Me. Nuts
Posted: Monday 17 June 2019 9:15
by JohnBoy32
I have had dealed with this a couple of months ago:
If I understand correctly Neo Coolcam released two different devices with same product type/Id.
For now openzwave didn’t support 2 config (version) file for same product, but it is something in pipeline.
The current work around is too and both entry in manufacturer_specific.xml file and comment one (in this case your, as the previous design). There seems to be some also for Fibaro and Qubino.
Posted: Monday 17 June 2019 9:16
by Rainman
I just bought this PIR, and I'm seeing the same issue. Also changing the PIR Motion detection sensitivity to lower does not work.
Any ideas would be welcome.
Posted: Monday 17 June 2019 21:38
by Rainman
Nevermind I got it working now. Just have to wakeup the pir by triple clicking the button inside right after sending an update from domoticz.
Posted: Saturday 22 June 2019 20:40
by tonbor
renerene wrote: Sunday 16 June 2019 12:28
simular symptoms:
here
Yes use the right XML configuration. Ozw has the wrong one...... I made an other one. See my other subject....
Posted: Monday 24 June 2019 13:23
by tonbor
