Did you press the 'Save Changes' button at the bottom ?
If yes, could you try to select 'Control Panel' from the dropdown, and set the configuration here
What is your domoticz version ?
Control panel and domoticz both show parameter 10 disabled (led off). Pressed three times fast on the PIR button to wake device.
Older neocam version 1 work flwaless
I have had dealed with this a couple of months ago:
If I understand correctly Neo Coolcam released two different devices with same product type/Id.
For now openzwave didn’t support 2 config (version) file for same product, but it is something in pipeline.
The current work around is too and both entry in manufacturer_specific.xml file and comment one (in this case your, as the previous design). There seems to be some also for Fibaro and Qubino.
renerene wrote: Sunday 16 June 2019 12:28
Allthough zwave setup says it is disabled, my LED still flashes. And is draining my battery.
simular symptoms: here
Anybody got it fixed?
Yes use the right XML configuration. Ozw has the wrong one...... I made an other one. See my other subject....
