NeoCoolcam PIR V2+ disable LED?
renerene
Post by renerene »
Allthough zwave setup says it is disabled, my LED still flashes. And is draining my battery.
simular symptoms: here
Anybody got it fixed?
gizmocuz
Re: NeoCoolcam PIR V2+ disable LED?
Post by gizmocuz »
Did you press the 'Save Changes' button at the bottom ?
If yes, could you try to select 'Control Panel' from the dropdown, and set the configuration here
What is your domoticz version ?
renerene
Post by renerene »
Control panel and domoticz both show parameter 10 disabled (led off). Pressed three times fast on the PIR button to wake device.
Older neocam version 1 work flwaless
Driving. Me. Nuts
JohnBoy32
Post by JohnBoy32 »
I have had dealed with this a couple of months ago:
If I understand correctly Neo Coolcam released two different devices with same product type/Id.
For now openzwave didn’t support 2 config (version) file for same product, but it is something in pipeline.
The current work around is too and both entry in manufacturer_specific.xml file and comment one (in this case your, as the previous design). There seems to be some also for Fibaro and Qubino.
Rainman
Domoticz version: 4.9700
Post by Rainman »
I just bought this PIR, and I'm seeing the same issue. Also changing the PIR Motion detection sensitivity to lower does not work.
Any ideas would be welcome.
Rainman
Post by Rainman »
Nevermind I got it working now. Just have to wakeup the pir by triple clicking the button inside right after sending an update from domoticz.
tonbor
Post by tonbor »
renerene wrote: Sunday 16 June 2019 12:28 Allthough zwave setup says it is disabled, my LED still flashes. And is draining my battery.
Yes use the right XML configuration. Ozw has the wrong one...... I made an other one. See my other subject....
tonbor
Post by tonbor »
