unknown location on FGMS001-ZW5
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
i think this message is logged every time the PIR sensor detects a movement.
i was wondering, is there a way to modify this UNKNOWN location so it reflects either a location or a name of the sensor.
2019-06-09 10:51:50.880 Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location)
Fishwaldo
Re: unknown location on FGMS001-ZW5
Post by Fishwaldo »
Only if the device supports sending location data. Most don’t.
Gravityz
Post by Gravityz »
ok, thanks
rinyheuvelman
Domoticz version: 4.10427
Post by rinyheuvelman »
Fishwaldo wrote: Tuesday 18 June 2019 16:19 Only if the device supports sending location data. Most don’t.
I ain't a software wizz, but my simple mind's firt response was: "WHYYY>>???"
Since one can specify the location in te OZW controlpanel?
So it should be just a matter of adding the specified location to the alarm when received by the controller.
Probably it's just to simple in my mind and much more complicated in reality
Fishwaldo
Post by Fishwaldo »
The device can. Send two types of alerts - a alert with “no location specified” or a alert with the location as a parameter. In this case the device is sending the first type of alert.
As to why, you have to ask the device vendor. OZW just reports what it receives.
