Use Toon as thermostat
tcviper
Post by tcviper »
Heya all,
I was wondering if someone had already thought of a way to re-flash the Toon Thermostat from Eneco and use it's display in the living through z-wave or something like that. Someone that tried to do anything like this by any chance? The firmware seems to be opensource aswell, it's just that im not technical enough to check things like that out myself: http://quby.nl/opensource/openembedded- ... r1.tar.bz2
Regards.
Derik
Re: Toon gebruiken als thermostaat
Post by Derik »
Zou leuk zijn..
Er is ook al iets als met opentherm
tcviper
Post by tcviper »
??! what is it with opentherm? cause i dont find any kind of thermostat in the Netherlands with opentherm and z-wave or something like that which looks good.
Derik
Post by Derik »
Ketel en thermostaat afhankelijk
Maar als ik het lees wel vooruitstrevend..
Makkelijk niet maar ja anders heeft iedereen het he...
http://www.domoticz.com/forum/viewtopic ... =opentherm
tcviper
Post by tcviper »
That's right though that doesnt solve my problem of having a thermostat in the living room :P
tcviper
Post by tcviper »
I have a Nefit Easy for now, great thing it's just missing integration with domoticz / fibaro.
pepijn
Post by pepijn »
This forum is english only, please translate
tcviper
Re: Use Toon as thermostat
Post by tcviper »
Anyone found any solutions yet to talk to Toon? :)
theezeefje
Post by theezeefje »
https://github.com/dennusb/eneco_toon_api
Someone at tweakers.net has written his own API to communicate with Toon !
tcviper
Post by tcviper »
Yep now we just need a way to do that from Domoticz (or Fibaro that is).
QuasaR
Post by QuasaR »
If this would be developed, what options do you guys need ?
I noticed that currently there is no 'good' support for GAS type. Also text, like status messages (idle / heating / home / away), isn't currently supported.
tcviper
Post by tcviper »
To be able to read out toons values (like power usage, gas usage) and set things like temperature, and program to Follow?
gizmocuz
Post by gizmocuz »
Toon could now be added as hardware in the current beta version (#1862), could not test it very good
tcviper
Post by tcviper »
How?
gizmocuz
Post by gizmocuz »
As explained above...
goto hardware setup, add the 'Toon Thermostat' supply your username (email) and password, and done
tcviper
Post by tcviper »
Oh how cool :) Could this now also be used to read gas/energy usage like with the p1 thing?
gizmocuz
Post by gizmocuz »
Maybe you should try first before asking ;) :mrgreen:
tcviper
Post by tcviper »
Hahaha, to excited here :) It works indeed, how awesome!! Thank you so much for this! Now we only need a way to change temperature/program :)
gizmocuz
Post by gizmocuz »
Program is not yet supported, i will implement this when everything else is working good (please log a few days, and check your graphs)
You can change your temperature by editing your setpoint device
tcviper
Post by tcviper »
Ah yes i see :) But there is no way to pick up the 4 programs and just click a button in domoticz like: - Weg, - Thuis, - Slapen, - Comfort are the 4 we use and that auto go on at specific times.
