Use Toon as thermostat
- tcviper
Heya all,
I was wondering if someone had already thought of a way to re-flash the Toon Thermostat from Eneco and use it's display in the living through z-wave or something like that. Someone that tried to do anything like this by any chance? The firmware seems to be opensource aswell, it's just that im not technical enough to check things like that out myself: http://quby.nl/opensource/openembedded- ... r1.tar.bz2
Regards.
Regards.
Derik
- Domoticz version: BETA
Re: Toon gebruiken als thermostaat
Zou leuk zijn..
Er is ook al iets als met opentherm
- tcviper
??! what is it with opentherm? cause i dont find any kind of thermostat in the Netherlands with opentherm and z-wave or something like that which looks good.
Derik
Ketel en thermostaat afhankelijk
Maar als ik het lees wel vooruitstrevend..
Makkelijk niet maar ja anders heeft iedereen het he...
http://www.domoticz.com/forum/viewtopic ... =opentherm
- tcviper
That's right though that doesnt solve my problem of having a thermostat in the living room
- tcviper
I have a Nefit Easy for now, great thing it's just missing integration with domoticz / fibaro.
pepijn
This forum is english only, please translate
- tcviper
Re: Use Toon as thermostat
Anyone found any solutions yet to talk to Toon?
theezeefje
https://github.com/dennusb/eneco_toon_api
Someone at tweakers.net has written his own API to communicate with Toon !
- tcviper
Yep now we just need a way to do that from Domoticz (or Fibaro that is).
QuasaR
If this would be developed, what options do you guys need ?
I noticed that currently there is no 'good' support for GAS type. Also text, like status messages (idle / heating / home / away), isn't currently supported.
- tcviper
To be able to read out toons values (like power usage, gas usage) and set things like temperature, and program to Follow?
- gizmocuz
Toon could now be added as hardware in the current beta version (#1862), could not test it very good
- gizmocuz
As explained above...
goto hardware setup, add the 'Toon Thermostat' supply your username (email) and password, and done
- tcviper
Oh how cool
Could this now also be used to read gas/energy usage like with the p1 thing?
- tcviper
Hahaha, to excited here
It works indeed, how awesome!! Thank you so much for this! Now we only need a way to change temperature/program
- gizmocuz
Program is not yet supported, i will implement this when everything else is working good (please log a few days, and check your graphs)
You can change your temperature by editing your setpoint device
- tcviper
Ah yes i see
But there is no way to pick up the 4 programs and just click a button in domoticz like: - Weg, - Thuis, - Slapen, - Comfort are the 4 we use and that auto go on at specific times.
