Bresser 5in1 support
Jeremob
Post by Jeremob »
I'm using a weather station Bresser 5in1, with RTL_433
This station works great in ssh (temperature, humidity, wind speed and direction, rain, etc ...) with : rtl_433 -f 868.272M
But with the same command line on Domoticz, I have only temperature and humidity
If I change parameters in domoticz, like that :rtl_433 -f 868.272M -F json
The domoticz Log show this :
2019-05-08 10:33:05.731 Status: Rtl433: Unhandled sensor reading, please report: (time,msg,codes,model,button,id,channel,battery,temperature_C,mic,subtype,rid,humidity,state,status,brand,rain_rate,rain_rate_mm_h,rain_rate_in_h,rain_total,rain_mm,rain_in,gust,average,direction,wind_max_m_s,wind_avg_m_s,wind_dir_deg,pressure_hPa,uv,power_W,energy_kWh,unit,group_call,command,dim,dim_value,wind_speed,wind_gust,wind_direction,wind_avg_km_h,wind_max_km_h,dipswitch,rbutton,device,temperature_F,battery_ok,setpoint_C,switch,cmd,cmd_id,tristate,direction_deg,speed,rain,msg_type,signal,radio_clock,sensor_code,uv_status,uv_index,lux,wm,seq,rainfall_mm,wind_speed_ms,gust_speed_ms,current,interval,learn,sensor_id,battery_low,sequence_num,message_type,wind_speed_mph,wind_speed_kph,wind_avg_mi_h,rain_inch,rc,gust_speed_mph,wind_max_mi_h,wind_approach,flags,maybetemp,binding_countdown,depth,depth_cm,dev_id,power0,power1,power2,node,ct1,ct2,ct3,ct4,Vrms/batt,batt_Vrms,temp1_C,temp2_C,temp3_C,temp4_C,temp5_C,temp6_C,pulse,address,button1,button2,button3,button4,data,sid,group,transmit,moisture,type,pressure_PSI,battery_mV,pressure_kPa,pulses,energy,len,to,from,payload,event,heartbeat,temperature1_C,temperature2_C,temperature_1_C,temperature_2_C,test,probe,water,humidity_1,ptemperature_C,phumidity,newbattery,heating,heating_temp,uvi,light_lux,counter,code,alarm,repeat,maybe_battery,device_type,raw_message,switch1,switch2,switch3,switch4,switch5,extradata,house_id,module_id,sensor_type,sensor_count,alarms,sensor_value,battery_voltage,failed,class,alert,secret_knock,relay,wind_dev_deg,exposure_mins,transmit_s
2019-05-08 10:33:05.731 |{"time" : "2019-05-08 10:33:05", "model" : "Bresser-5in1", "id" : 225, "temperature_C" : 10.500, "humidity" : 87, "wind_gust" : 1.400, "wind_speed" : 1.000, "wind_dir_deg" : 202.500, "rain_mm" : 16.800, "mic" : "CHECKSUM"}
How to get other information ? This is a domoticz configuration to do ? Or rtl_433 configuration ?
Thanks for your help !
Jeremob
Re: Bresser 5in1 support
Post by Jeremob »
No news ?
some users uses RTL_433 with a weather station ?
Jeremob
Post by Jeremob »
1 year later, the Bresser weatherstation has been added in the last Domoticz version (2020.1)
Great ! But some issues ...
In this view, we can see the Temp and Wind Direction. That's all ...
In the LOG windows, no wind speed or direction :
Don't understand why ... Wrong support added ?
Any ideas ?
Jeremob
Post by Jeremob »
Juste another screenshot, I can't see the value is received by Domoticz, but not shown in the graph ...
Any ideas ?
annegerben
Post by annegerben »
could this be a bug? I see the same with AlectoV1-Wind
Annotation 2020-05-14 110435.jpg (15.4 KiB) Viewed 5875 times
Annotation 2020-05-14.jpg (25.99 KiB) Viewed 5875 times
direction is shown and updated but no wind speeds.
I'm running 2020.2 btw
fenquick
Post by fenquick »
Confirming exactly same issue.
annegerben
Jeremob wrote: Thursday 14 May 2020 9:28 Hi,
Any ideas ?
can you try latest beta?
and if that doesn't work can you share the output of "rtl_433 -F json
Jeremob
Post by Jeremob »
annegerben wrote: Thursday 28 May 2020 15:31
Any ideas ?
Sorry for my late answer
I'm using the last stable version, just updated today : Version: 2020.2
Results of rtl_433 -F json -f 868272000 (specific frequency of my weather station) :
{"time" : "2020-06-03 15:08:35", "model" : "Bresser-5in1", "id" : 183, "temperature_C" : 20.100, "humidity" : 61, "wind_gust" : 0.800, "wind_speed" : 0.800, "wind_dir_deg" : 247.500, "rain_mm" : 31.600, "mic" : "CHECKSUM"}
{"time" : "2020-06-03 15:08:47", "model" : "Bresser-5in1", "id" : 183, "temperature_C" : 20.100, "humidity" : 61, "wind_gust" : 0.800, "wind_speed" : 0.800, "wind_dir_deg" : 247.500, "rain_mm" : 31.600, "mic" : "CHECKSUM"}
{"time" : "2020-06-03 15:08:59", "model" : "Bresser-5in1", "id" : 183, "temperature_C" : 20.100, "humidity" : 60, "wind_gust" : 0.000, "wind_speed" : 0.600, "wind_dir_deg" : 247.500, "rain_mm" : 31.600, "mic" : "CHECKSUM"}
{"time" : "2020-06-03 15:09:11", "model" : "Bresser-5in1", "id" : 183, "temperature_C" : 20.000, "humidity" : 61, "wind_gust" : 0.800, "wind_speed" : 0.600, "wind_dir_deg" : 247.500, "rain_mm" : 31.600, "mic" : "CHECKSUM"}
Everything seems to be ok on this output ?
No wind speed infos in Domoticz ...
annegerben
Jeremob wrote: Wednesday 03 June 2020 15:09
Any ideas ?
for the wind speed it does not show units like m/s.
Do you you have a stand alone unit with the wind meter? (so you can find out in which units "wind_gust" : 0.800, "wind_speed" : 0.600 are).
wm62
Domoticz version: 4.97
Post by wm62 »
Any manual how to connect the 5in1 ? Can't find any , any help welcome :D :D :D :D
annegerben
wm62 wrote: Thursday 09 July 2020 16:16 Any manual how to connect the 5in1 ? Can't find any , any help welcome :D :D :D :D
you need a https://www.domoticz.com/wiki/Rtl_433 or https://www.domoticz.com/wiki/RFXtrx433E or https://www.domoticz.com/wiki/RFLink which can receive 433mhz
wm62
Post by wm62 »
yeah , forgot to mention, i've got an RFLink wich is receivering everything in my home except the Bresser...
Jeremob
Post by Jeremob »
Bresser = 866mhz...
Jeremob
Post by Jeremob »
Finally, my bresser 5in1 doesn't work anymore.
The complete weather station has been changed by Amazon 2 times, and the problem still the same
The remote display show "Err" on datas provided by the external module.
I think the transmitter is down after 6 months...
I just bought another weather station Oregon, in 433mhz, more simple with domoticz and rfxcom
For me Bresser is a really bad quality. Specially this model.
