WAN login problem
MasMat
Domoticz version: 2025.1
WAN login problem
Post by MasMat »
Can anyone help with this problem?
When I open the dashboard (192.168.0.200:8080) locally there are no problems. When I try to access it remotely the login(?) seems to hang at a screen like in the attachment. I have login set to BasicAuth.
I just did a reinstall to newest Domoticz on Ubuntu running on and older laptop (2010). This is not a port fwd problem clearly. Looking at the log on the machine there's nothing special when I attempt outside access with another device.
Once I get http working https is next.
Ideas? Couldnt find similar on the forum.
mpx2
Domoticz version: 4.10717
Re: WAN login problem
Post by mpx2 »
Does the same problem occur with Firefox, Chrome and Edge?
I have had routers which have problems with portforwarding if port is 80 or 8080. There's some kind of conflict because those ports are used for accessing router settings. Connection was established but after few bytes connection halts. Browser showed empty page. To be sure try eg port 4040.
MasMat
Post by MasMat »
Chrome yes, tried Safari but it worked only once AND didnt prompt for password. Next time I connected it said Domoticz offline.
Again this is NOT a router problem because the system has worked fine but after updating Domoticz it does this.
Is there a fix for the Chrome problem which I read causes problems? On my Android Chrome is default and I would prefer to use it.
gerardsoraya
Domoticz version: 2024.7
Post by gerardsoraya »
I had the same problems Butt after clearing cache of Chrome it is working Again, my idea about it was a Chrome update. You also putt a shortcut on your home screen? Remote it and replace it after clearing cache
Verstuurd vanaf mijn SM-G965F met Tapatalk
Rpi 4
rflink 433 mhz
Philips hue
p1 smart meter cable
P1 smart meter solar
Lyric t6
MasMat
Post by MasMat »
OK, so most likely it's a browser problem: cache clearing works only once and even then not every time. Plus it is SLOW on android.
Easiest solution: I use incognito window on Chrome. Works every time and is fast as normal browsing.
Now I have to figure out how to make a shortcut on my phone desktop that opens an incognito window..
emme
Domoticz version: latest
Post by emme »
are you behind a firewall?
"We always done this way"
MasMat
Post by MasMat »
Just what is on the router.
So http working, gotta improve security next, if that's what you're implying :)
