How to check on which device lua scripts runs
Posted: Sunday 07 April 2019 7:27
by Rohald
I've one question i have multiple RPI's with domoticz which all use the same scripts but in Bash I know how to select on which host the scripts runs and than executes the script on the other hosts the script won't be executed.
HOST=$(hostname)
if [ "$HOST" = "domoticz" ];
then
<EXECUTE>
exit
fi
Is the above also possible with LUA? And how could this be configured?
Re: How to check on which device lua scripts runs
Posted: Sunday 07 April 2019 12:39
by waaren
Rohald wrote: Sunday 07 April 2019 7:27
I have multiple RPI's with domoticz which all use the same scripts. In Bash I know how to select on which host the scripts runs.
Is that also possible with LUA? And how could this be configured?
with dzVents (= Lua) and if you use a recent beta, you can identify the name of your system by the atrribute
domoticz.settings.location.name which shows the Name you set in Location
- System settings location
- Name.png (63.69 KiB) Viewed 1064 times
Posted: Sunday 07 April 2019 12:58
by jvdz
... or simply create a similar uservariable on each system and set that to the systemname. Then you can test the content of that user variable in the script.
Jos
Posted: Tuesday 09 April 2019 15:47
by Rohald
waaren wrote: Sunday 07 April 2019 12:39
Thx works great!!!!
