How to check on which device lua scripts runs
Rohald
Post by Rohald »
I've one question i have multiple RPI's with domoticz which all use the same scripts but in Bash I know how to select on which host the scripts runs and than executes the script on the other hosts the script won't be executed.
HOST=$(hostname)
if [ "$HOST" = "domoticz" ];
then
<EXECUTE>
exit
fi
Is the above also possible with LUA? And how could this be configured?
Re: How to check on which device lua scripts runs
Rohald wrote: Sunday 07 April 2019 7:27 I have multiple RPI's with domoticz which all use the same scripts. In Bash I know how to select on which host the scripts runs.
Is that also possible with LUA? And how could this be configured?
with dzVents (= Lua) and if you use a recent beta, you can identify the name of your system by the atrribute domoticz.settings.location.name which shows the Name you set in Location
System settings location
jvdz
Domoticz version: 4.107
Post by jvdz »
... or simply create a similar uservariable on each system and set that to the systemname. Then you can test the content of that user variable in the script.
Jos
Rohald
Post by Rohald »
waaren wrote: Sunday 07 April 2019 12:39
Thx works great!!!!
