I've just received my Jetson Nano and finished building/compiling Domoticz per instructions on the wiki.
Now I did see some warnings/errors during compilation, see also attached file. I know, I know, I should've read the wiki better and removed libboost before continuing, but I was unsure whether any of the pre installed nvidia software would also require it.
[ 14%] Building C object MQTT/CMakeFiles/mqtt.dir/net_mosq.c.o
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c: In function ‘_mosquitto_net_cleanup’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:114:2: warning: ‘ERR_remove_state’ is deprecated [-Wdeprecated-declarations]
ERR_remove_state(0);
In file included from /usr/include/openssl/ui.h:13:0,
from /usr/include/openssl/engine.h:29,
from /home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:55:
/usr/include/openssl/err.h:248:1: note: declared here
DEPRECATEDIN_1_0_0(void ERR_remove_state(unsigned long pid))
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c: In function ‘_mosquitto_socket_connect’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:428:4: warning: ‘TLSv1_2_client_method’ is deprecated [-Wdeprecated-declarations]
mosq->ssl_ctx = SSL_CTX_new(TLSv1_2_client_method());
In file included from /usr/include/openssl/ct.h:13:0,
from /usr/include/openssl/ssl.h:61,
from /home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.h:28,
from /home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:57:
/usr/include/openssl/ssl.h:1638:1: note: declared here
DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_2_client_method(void)) /* TLSv1.2 */
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:430:4: warning: ‘TLSv1_1_client_method’ is deprecated [-Wdeprecated-declarations]
mosq->ssl_ctx = SSL_CTX_new(TLSv1_1_client_method());
/usr/include/openssl/ssl.h:1632:1: note: declared here
DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_1_client_method(void)) /* TLSv1.1 */
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:432:4: warning: ‘TLSv1_client_method’ is deprecated [-Wdeprecated-declarations]
mosq->ssl_ctx = SSL_CTX_new(TLSv1_client_method());
/usr/include/openssl/ssl.h:1626:1: note: declared here
DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_client_method(void)) /* TLSv1.0 */
[ 15%] Building C object MQTT/CMakeFiles/mqtt.dir/read_handle.c.oCode: Select all
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/tls_mosq.c.o
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c: In function ‘_mosquitto_verify_certificate_hostname’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:130:5: warning: ‘ASN1_STRING_data’ is deprecated [-Wdeprecated-declarations]
data = ASN1_STRING_data(nval->d.dNSName);
In file included from /usr/include/openssl/bn.h:31:0,
from /usr/include/openssl/asn1.h:24,
from /usr/include/openssl/objects.h:916,
from /usr/include/openssl/evp.h:27,
from /usr/include/openssl/x509.h:23,
from /usr/include/openssl/x509v3.h:14,
from /home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:29:
/usr/include/openssl/asn1.h:553:1: note: declared here
DEPRECATEDIN_1_1_0(unsigned char *ASN1_STRING_data(ASN1_STRING *x))
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:136:5: warning: ‘ASN1_STRING_data’ is deprecated [-Wdeprecated-declarations]
data = ASN1_STRING_data(nval->d.iPAddress);
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/util_mosq.c.oThanks in advance,
IceBlackz
edit: after running sudo apt update and upgrade on the default supplied firmware by Nvidia, the installed version of libboost is 1.65.1
