Compiling results on Nvidia Jetson Nano
IceBlackz
Post by IceBlackz »
Hello all,
I've just received my Jetson Nano and finished building/compiling Domoticz per instructions on the wiki.
Now I did see some warnings/errors during compilation, see also attached file. I know, I know, I should've read the wiki better and removed libboost before continuing, but I was unsure whether any of the pre installed nvidia software would also require it.
[ 14%] Building C object MQTT/CMakeFiles/mqtt.dir/net_mosq.c.o
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c: In function ‘_mosquitto_net_cleanup’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:114:2: warning: ‘ERR_remove_state’ is deprecated [-Wdeprecated-declarations]
  ERR_remove_state(0);
In file included from /usr/include/openssl/ui.h:13:0,
                 from /usr/include/openssl/engine.h:29,
                 from /home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:55:
/usr/include/openssl/err.h:248:1: note: declared here
 DEPRECATEDIN_1_0_0(void ERR_remove_state(unsigned long pid))
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c: In function ‘_mosquitto_socket_connect’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:428:4: warning: ‘TLSv1_2_client_method’ is deprecated [-Wdeprecated-declarations]
    mosq->ssl_ctx = SSL_CTX_new(TLSv1_2_client_method());
In file included from /usr/include/openssl/ct.h:13:0,
                 from /usr/include/openssl/ssl.h:61,
                 from /home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.h:28,
                 from /home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:57:
/usr/include/openssl/ssl.h:1638:1: note: declared here
 DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_2_client_method(void)) /* TLSv1.2 */
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:430:4: warning: ‘TLSv1_1_client_method’ is deprecated [-Wdeprecated-declarations]
    mosq->ssl_ctx = SSL_CTX_new(TLSv1_1_client_method());
/usr/include/openssl/ssl.h:1632:1: note: declared here
 DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_1_client_method(void)) /* TLSv1.1 */
/home/rootuser/Domoticz/dev-domoticz/MQTT/net_mosq.c:432:4: warning: ‘TLSv1_client_method’ is deprecated [-Wdeprecated-declarations]
    mosq->ssl_ctx = SSL_CTX_new(TLSv1_client_method());
/usr/include/openssl/ssl.h:1626:1: note: declared here
 DEPRECATEDIN_1_1_0(__owur const SSL_METHOD *TLSv1_client_method(void)) /* TLSv1.0 */
[ 15%] Building C object MQTT/CMakeFiles/mqtt.dir/read_handle.c.o
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/tls_mosq.c.o
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c: In function ‘_mosquitto_verify_certificate_hostname’:
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:130:5: warning: ‘ASN1_STRING_data’ is deprecated [-Wdeprecated-declarations]
     data = ASN1_STRING_data(nval->d.dNSName);
In file included from /usr/include/openssl/bn.h:31:0,
                 from /usr/include/openssl/asn1.h:24,
                 from /usr/include/openssl/objects.h:916,
                 from /usr/include/openssl/evp.h:27,
                 from /usr/include/openssl/x509.h:23,
                 from /usr/include/openssl/x509v3.h:14,
                 from /home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:29:
/usr/include/openssl/asn1.h:553:1: note: declared here
 DEPRECATEDIN_1_1_0(unsigned char *ASN1_STRING_data(ASN1_STRING *x))
/home/rootuser/Domoticz/dev-domoticz/MQTT/tls_mosq.c:136:5: warning: ‘ASN1_STRING_data’ is deprecated [-Wdeprecated-declarations]
     data = ASN1_STRING_data(nval->d.iPAddress);
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/util_mosq.c.o
And some more errors. I'm just wondering, can any of these do any real harm? I've already fired it up and it seems to be working just fine..
Thanks in advance,
IceBlackz
edit: after running sudo apt update and upgrade on the default supplied firmware by Nvidia, the installed version of libboost is 1.65.1
makelog_domoticz_safe.txt
(33.81 KiB) Downloaded 47 times
Justino
Domoticz version: 4.10548
Re: Compiling results on Nvidia Jetson Nano
Post by Justino »
IceBlackz wrote: Friday 29 March 2019 19:29 Hello all,
This look promising!
Do you have it working without error already? Planning on ordering one to sometime soon.
Mosquitto is primarily used for the Zigbee2MQTT function if i'm correct, i'm using it to, so maybe that part will not function?
Maybe you could test it with "-Wdeprecated-declarations" like the errors is telling?
Kind regards
IceBlackz
Post by IceBlackz »
I haven't tried recompiling it yet, it seems to be working just fine for now. But I'm only using it with MQTT controlled Sonoff S20 switches which run Tasmota, not something very heavy or anything Zigbee related. I might try it again when I have time, but for now its running just fine!
