Hikvision Camera Linecrossing detection
All kinds of 'OS' scripts
Andyyyy
Post by Andyyyy »
i take the script form ccontavalli (https://github.com/ccontavalli/hicknotify) and change it a little bit to get the linecrossing function from my hikvision to domoticz on my Rpi3.
The script is written in golang.
install golang:
pi@Domoticz:~ $ sudo apt install golang
copy hiknotify.go and config.json to /domoticz/scripts/ipcamera/
hiknotify.go
package main
import "fmt"
import "net/http"
import "bufio"
import "sync"
import "bytes"
import "regexp"
import "strconv"
import "time"
import "encoding/json"
import "os"
type Event struct {
  etype string
  estate string
  ecount int
  camera *Camera
func (e *Event) Complete() bool {
  if len(e.etype) > 0 && len(e.estate) > 0 && e.ecount > 0 {
    return true
  return false
func (e *Event) Reset() {
  *e = Event{}
func GenerateTimeout(config Config, camera *Camera, lc chan bool, ec chan Event) {
  count := 1
  for {
    select {
      case <-lc:
        break;
      case <-time.After(time.Second * config.WatchdogTime):
        ec <- Event{"watchdog", "lost-signal", count, camera}
        count += 1
        break
func GenerateEvents(wg *sync.WaitGroup, config Config, camera Camera, ec chan Event) {
  var last_attempt time.Time
  lc := make(chan bool)
  event := Event{camera: &camera}
  defer wg.Done()
  go GenerateTimeout(config, &camera, lc, ec)
  for {
    if time.Now().Before(last_attempt.Add(time.Second * config.ErrorRetryTime)) {
      fmt.Println("SLEEPING FOR SECONDS", config.ErrorRetryTime)
      time.Sleep(config.ErrorRetryTime * time.Second)
    last_attempt = time.Now()
    client := &http.Client{}
    // This will break the stream of responses, the response has
    // to complete within 10 seconds.
    // client.Timeout = time.Second * 10
    etyper := regexp.MustCompile("eventType>(.*)</eventType")
    estater := regexp.MustCompile("eventState>(.*)</eventState")
    ecountr := regexp.MustCompile("activePostCount>(.*)</activePostCount")
    request, err := http.NewRequest("GET", camera.Url, nil)
    if err != nil {
      fmt.Println("REQUEST ERROR", camera, err)
      continue
    request.SetBasicAuth(camera.Username, camera.Password)
    resp, err := client.Do(request)
    if err != nil {
      fmt.Println("DO ERROR", camera, err)
      continue
    reader := bufio.NewReader(resp.Body)
    for {
      line, err := reader.ReadBytes('\n')
      if err != nil {
        fmt.Println("READER ERROR", camera, err)
        break
      // Send keepalive
      lc <- true
      //Uncomment this line to dump all notifications
      fmt.Println(string(line))
      line = bytes.TrimRight(line, "\n\r")
      etypes := etyper.FindSubmatch(line)
      if len(etypes) > 0 {
        event.etype = string(etypes[1])
      estates := estater.FindSubmatch(line)
      if len(estates) > 0 {
        event.estate = string(estates[1])
      ecounts := ecountr.FindSubmatch(line)
      if len(ecounts) > 0 {
        count, _ := strconv.Atoi(string(ecounts[1]))
        event.ecount = count + 1
      if event.Complete() {
        if event.etype != "videoloss" {
        //if event.etype == "videoloss" {
          ec <- event
		//fmt.Println("SENDING NOTIFICATION FOR", event.etype, event.estate, event.ecount)
	        event.Reset()
        event.camera = &camera
type Camera struct {
  Url string
  Name string
  Username string
  Password string
type Config struct {
  Cameras []Camera
  DomoticzHost string
  DomoticzPort string
  DomoticzBasicAuth bool
  DomoticzUsername string
  DomoticzPassword string
  LineCrossidx string
  DampeningTime time.Duration
  ErrorRetryTime time.Duration
  WatchdogTime time.Duration
func LoadConfig() (Config, error) {
  file, err := os.Open("/home/pi/domoticz/scripts/ipcamera/config.json")
  if err != nil {
    return Config{}, err
  decoder := json.NewDecoder(file)
  configuration := Config{}
  err = decoder.Decode(&configuration)
  if err != nil {
  if configuration.DampeningTime <= 0 {
    configuration.DampeningTime = 10
  if configuration.ErrorRetryTime <= 0 {
    configuration.ErrorRetryTime = 5
  if configuration.WatchdogTime <= 0 {
    configuration.WatchdogTime = 5
  return configuration, nil
func domoticz(config Config, event Event, now time.Time) {
  if event.etype == "linedetection" && event.estate == "active" {
    fmt.Println("SENDING NOTIFICATION FOR", event, event.camera, now)
    urlstr := fmt.Sprintf("http://%s:%s/json.htm?type=command&param=switchlight&idx=%s&switchcmd=On", config.DomoticzHost, config.DomoticzPort, config.LineCrossidx)
    request, err := http.NewRequest("GET", urlstr, nil)
    if config.DomoticzBasicAuth {
	  request.SetBasicAuth(config.DomoticzUsername, config.DomoticzPassword)
    fmt.Println(urlstr)
    client.Do(request)
    if err != nil {
      fmt.Println(err)
func main() {
  config, err := LoadConfig()
  if err != nil {
    fmt.Println("COULD NOT READ CONFIG", err)
    return
  ec := make(chan Event)
  wg := &sync.WaitGroup{}
  for _, camera := range config.Cameras {
    fmt.Println("Hiknotify starting... " )
    fmt.Println("Hiknotify listening to Camera : ", config.Cameras )
    fmt.Println("Hiknotify started ..." )
    wg.Add(1)
    go GenerateEvents(wg, config, camera, ec)
  type DampKey struct {
    event string
    camera *Camera
  dampener := make(map[DampKey]time.Time)
  for {
    select {
      case event := <-ec:
        key := DampKey{event.etype, event.camera}
        last, ok := dampener[key]
        now := time.Now()
        if !ok || now.After(last.Add(config.DampeningTime * time.Second)) {
          domoticz(config, event, now)
          dampener[key] = now
        } else {
          fmt.Println("TIME DAMPENED ", event, key)
          dampener[key] = time.Now()
        break;
  wg.Wait()
config.json
 "Cameras": [
  {"Url": "http://ipaddress_cam/ISAPI/Event/notification/alertStream",
   "Name": "your CameraName",
   "Username": "username_cam",
   "Password": "password_cam"}
"DampeningTime": 10,
"WatchdogTime": 10,
"ErrorRetryTime": 5,
"DomoticzHost": "ipaddress_Rpi",
"DomoticzPort": "8080",
"DomoticzBasicAuth": true,
"DomoticzUsername": "username_domo",
"DomoticzPassword": "password_domo",
"LineCrossidx": "idx_domo"
next you can build the script:
pi@Domoticz:~/domoticz/scripts/ipcamera $ go build -o hiknotify
its time to test:
pi@Domoticz:~/domoticz/scripts/ipcamera $ ./hiknotify
at least the script for autostart:
hiknotify.sh
#! /bin/sh
### BEGIN INIT INFO
# Provides:          hiknotify
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Service to connect to Hikvision Camera
# Description:       Service to connect to Hikvision Camera
### END INIT INFO
case "$1" in
  start)
    echo "Start Hiknotify Service"
    # run application you want to start
    ./home/pi/domoticz/scripts/ipcamera/hiknotify &
  stop)
    echo "Stopping Hiknotify Service"
    # kill application you want to stop
    killall hiknotify
    echo "Usage: /etc/init.d/lgac_server{start|stop}"
    exit 1
esac
exit 0
and
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo cp hiknotify.sh /etc/init.d
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo chmod +x /etc/init.d/hiknotify.sh
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo update-rc.d hiknotify.sh defaults
acoustic
Re: Hikvision Camera Linecrossing detection
Post by acoustic »
Hi Andyyyy,
Could you point me in the right direction for getting this script to notify Domoticz from multiple Hikvision cameras to their respective IDX's?
I've been enjoying your efforts with this for quite some time, so a thank is in its place!
Cheers,
acoustic
