i take the script form ccontavalli (https://github.com/ccontavalli/hicknotify) and change it a little bit to get the linecrossing function from my hikvision to domoticz on my Rpi3.
The script is written in golang.
install golang:
pi@Domoticz:~ $ sudo apt install golanghiknotify.go
package main
import "fmt"
import "net/http"
import "bufio"
import "sync"
import "bytes"
import "regexp"
import "strconv"
import "time"
import "encoding/json"
import "os"
type Event struct {
etype string
estate string
ecount int
camera *Camera
func (e *Event) Complete() bool {
if len(e.etype) > 0 && len(e.estate) > 0 && e.ecount > 0 {
return true
return false
func (e *Event) Reset() {
*e = Event{}
func GenerateTimeout(config Config, camera *Camera, lc chan bool, ec chan Event) {
count := 1
for {
select {
case <-lc:
break;
case <-time.After(time.Second * config.WatchdogTime):
ec <- Event{"watchdog", "lost-signal", count, camera}
count += 1
break
func GenerateEvents(wg *sync.WaitGroup, config Config, camera Camera, ec chan Event) {
var last_attempt time.Time
lc := make(chan bool)
event := Event{camera: &camera}
defer wg.Done()
go GenerateTimeout(config, &camera, lc, ec)
for {
if time.Now().Before(last_attempt.Add(time.Second * config.ErrorRetryTime)) {
fmt.Println("SLEEPING FOR SECONDS", config.ErrorRetryTime)
time.Sleep(config.ErrorRetryTime * time.Second)
last_attempt = time.Now()
client := &http.Client{}
// This will break the stream of responses, the response has
// to complete within 10 seconds.
// client.Timeout = time.Second * 10
etyper := regexp.MustCompile("eventType>(.*)</eventType")
estater := regexp.MustCompile("eventState>(.*)</eventState")
ecountr := regexp.MustCompile("activePostCount>(.*)</activePostCount")
request, err := http.NewRequest("GET", camera.Url, nil)
if err != nil {
fmt.Println("REQUEST ERROR", camera, err)
continue
request.SetBasicAuth(camera.Username, camera.Password)
resp, err := client.Do(request)
if err != nil {
fmt.Println("DO ERROR", camera, err)
continue
reader := bufio.NewReader(resp.Body)
for {
line, err := reader.ReadBytes('\n')
if err != nil {
fmt.Println("READER ERROR", camera, err)
break
// Send keepalive
lc <- true
//Uncomment this line to dump all notifications
fmt.Println(string(line))
line = bytes.TrimRight(line, "\n\r")
etypes := etyper.FindSubmatch(line)
if len(etypes) > 0 {
event.etype = string(etypes[1])
estates := estater.FindSubmatch(line)
if len(estates) > 0 {
event.estate = string(estates[1])
ecounts := ecountr.FindSubmatch(line)
if len(ecounts) > 0 {
count, _ := strconv.Atoi(string(ecounts[1]))
event.ecount = count + 1
if event.Complete() {
if event.etype != "videoloss" {
//if event.etype == "videoloss" {
ec <- event
//fmt.Println("SENDING NOTIFICATION FOR", event.etype, event.estate, event.ecount)
event.Reset()
event.camera = &camera
type Camera struct {
Url string
Name string
Username string
Password string
type Config struct {
Cameras []Camera
DomoticzHost string
DomoticzPort string
DomoticzBasicAuth bool
DomoticzUsername string
DomoticzPassword string
LineCrossidx string
DampeningTime time.Duration
ErrorRetryTime time.Duration
WatchdogTime time.Duration
func LoadConfig() (Config, error) {
file, err := os.Open("/home/pi/domoticz/scripts/ipcamera/config.json")
if err != nil {
return Config{}, err
decoder := json.NewDecoder(file)
configuration := Config{}
err = decoder.Decode(&configuration)
if err != nil {
if configuration.DampeningTime <= 0 {
configuration.DampeningTime = 10
if configuration.ErrorRetryTime <= 0 {
configuration.ErrorRetryTime = 5
if configuration.WatchdogTime <= 0 {
configuration.WatchdogTime = 5
return configuration, nil
func domoticz(config Config, event Event, now time.Time) {
if event.etype == "linedetection" && event.estate == "active" {
fmt.Println("SENDING NOTIFICATION FOR", event, event.camera, now)
urlstr := fmt.Sprintf("http://%s:%s/json.htm?type=command¶m=switchlight&idx=%s&switchcmd=On", config.DomoticzHost, config.DomoticzPort, config.LineCrossidx)
request, err := http.NewRequest("GET", urlstr, nil)
if config.DomoticzBasicAuth {
request.SetBasicAuth(config.DomoticzUsername, config.DomoticzPassword)
fmt.Println(urlstr)
client.Do(request)
if err != nil {
fmt.Println(err)
func main() {
config, err := LoadConfig()
if err != nil {
fmt.Println("COULD NOT READ CONFIG", err)
return
ec := make(chan Event)
wg := &sync.WaitGroup{}
for _, camera := range config.Cameras {
fmt.Println("Hiknotify starting... " )
fmt.Println("Hiknotify listening to Camera : ", config.Cameras )
fmt.Println("Hiknotify started ..." )
wg.Add(1)
go GenerateEvents(wg, config, camera, ec)
type DampKey struct {
event string
camera *Camera
dampener := make(map[DampKey]time.Time)
for {
select {
case event := <-ec:
key := DampKey{event.etype, event.camera}
last, ok := dampener[key]
now := time.Now()
if !ok || now.After(last.Add(config.DampeningTime * time.Second)) {
domoticz(config, event, now)
dampener[key] = now
} else {
fmt.Println("TIME DAMPENED ", event, key)
dampener[key] = time.Now()
break;
wg.Wait()
}Code: Select all
"Cameras": [
{"Url": "http://ipaddress_cam/ISAPI/Event/notification/alertStream",
"Name": "your CameraName",
"Username": "username_cam",
"Password": "password_cam"}
"DampeningTime": 10,
"WatchdogTime": 10,
"ErrorRetryTime": 5,
"DomoticzHost": "ipaddress_Rpi",
"DomoticzPort": "8080",
"DomoticzBasicAuth": true,
"DomoticzUsername": "username_domo",
"DomoticzPassword": "password_domo",
"LineCrossidx": "idx_domo"
}Code: Select all
pi@Domoticz:~/domoticz/scripts/ipcamera $ go build -o hiknotifyCode: Select all
pi@Domoticz:~/domoticz/scripts/ipcamera $ ./hiknotifyhiknotify.sh
#! /bin/sh
### BEGIN INIT INFO
# Provides: hiknotify
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Service to connect to Hikvision Camera
# Description: Service to connect to Hikvision Camera
### END INIT INFO
case "$1" in
start)
echo "Start Hiknotify Service"
# run application you want to start
./home/pi/domoticz/scripts/ipcamera/hiknotify &
stop)
echo "Stopping Hiknotify Service"
# kill application you want to stop
killall hiknotify
echo "Usage: /etc/init.d/lgac_server{start|stop}"
exit 1
esac
exit 0Code: Select all
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo cp hiknotify.sh /etc/init.d
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo chmod +x /etc/init.d/hiknotify.sh
pi@Domoticz:~/domoticz/scripts/ipcamera $ sudo update-rc.d hiknotify.sh defaults
