It is a native Python3 application designed to run on all kind of available Raspberry PI SBC's and Raspbian Lite. Main goal was to create a fast and easy way to attach and handle sensors without actually programming. (If anyone is familiar with the ESPEasy name from the ESP8266 world, this is a very similar approach for the RPI.)
Installation needs some basic Linux console knowledge, but after that, a simple dependency solver will help to activate the needed devices.
Main features:
- web based GUI (port 80 if root, or 8080, 8008 if not)
- commands can be executed remotely by HTTP/MQTT/ESPEasy P2P-UDP
- ESPEasy compatible "Rules" event-driven scripting can be used
- Sensors are able to report it's values to Domoticz/Generic style MQTT
- Supported sensor types are: Generic GPIO Switch, DS18B20, DHT22, Wiegand reader, BH1750, Si7021/HTU21D, TSL2561, SSD1306 OLED (LUMA), MLX90614, ADS1x15, BME280, Neopixel/WS2812 (rpi_ws281x), AM2320, Rotary encoder, APDS9960, Simple RF433 receiver/transmitter (RCSwitch), VL53L0X, MAX44009, USB Relay board, Temper USB thermometer
https://github.com/enesbcs/rpieasy
RPIEasy - Python based multisensor for RPI
lwolf
Re: RPIEasy - Python based multisensor for RPI
FYI: An instructable has been made about using RPIEasy
https://www.instructables.com/id/RPIEas ... or-Device/
Thorgal789
- Target OS: -
Hello, have you some information how to connect it to domoticz ?
Wich one hardware we need to use ?
lwolf
As it is shown in the Instructable at Step 5: a "Controller" has to be added either Domoticz HTTP or Domoticz MQTT to use it with Domoticz.Thorgal789 wrote: Wednesday 25 December 2019 15:55 Hello, have you some information how to connect it to domoticz ?
The method is very similar as with ESPEasy:
https://www.letscontrolit.com/wiki/inde ... icz_Switch
https://www.domoticz.com/wiki/ESPEasy
Thorgal789
- Target OS: -
Thx, was the part I was looking for ^^. To resume the application deal directly with the domoticz's device using json.lwolf wrote: Thursday 26 December 2019 17:07 As it is shown in the Instructable at Step 5: a "Controller" has to be added either Domoticz HTTP or Domoticz MQTT to use it with Domoticz.
lwolf
From today commit, RPIEasy has an MQTT Autodiscovery controller, which should also work with Domoticz!
