RPIEasy - Python based multisensor for RPI
lwolf
Post by lwolf »
It is a native Python3 application designed to run on all kind of available Raspberry PI SBC's and Raspbian Lite. Main goal was to create a fast and easy way to attach and handle sensors without actually programming. (If anyone is familiar with the ESPEasy name from the ESP8266 world, this is a very similar approach for the RPI.)
Installation needs some basic Linux console knowledge, but after that, a simple dependency solver will help to activate the needed devices.
Main features:
- web based GUI (port 80 if root, or 8080, 8008 if not)
- commands can be executed remotely by HTTP/MQTT/ESPEasy P2P-UDP
- ESPEasy compatible "Rules" event-driven scripting can be used
- Sensors are able to report it's values to Domoticz/Generic style MQTT
- Supported sensor types are: Generic GPIO Switch, DS18B20, DHT22, Wiegand reader, BH1750, Si7021/HTU21D, TSL2561, SSD1306 OLED (LUMA), MLX90614, ADS1x15, BME280, Neopixel/WS2812 (rpi_ws281x), AM2320, Rotary encoder, APDS9960, Simple RF433 receiver/transmitter (RCSwitch), VL53L0X, MAX44009, USB Relay board, Temper USB thermometer
https://github.com/enesbcs/rpieasy
lwolf
Re: RPIEasy - Python based multisensor for RPI
Post by lwolf »
FYI: An instructable has been made about using RPIEasy
https://www.instructables.com/id/RPIEas ... or-Device/
Thorgal789
Post by Thorgal789 »
Hello, have you some information how to connect it to domoticz ?
Wich one hardware we need to use ?
lwolf
Post by lwolf »
Thorgal789 wrote: Wednesday 25 December 2019 15:55 Hello, have you some information how to connect it to domoticz ?
As it is shown in the Instructable at Step 5: a "Controller" has to be added either Domoticz HTTP or Domoticz MQTT to use it with Domoticz.
The method is very similar as with ESPEasy:
https://www.letscontrolit.com/wiki/inde ... icz_Switch
https://www.domoticz.com/wiki/ESPEasy
Thorgal789
lwolf wrote: Thursday 26 December 2019 17:07 As it is shown in the Instructable at Step 5: a "Controller" has to be added either Domoticz HTTP or Domoticz MQTT to use it with Domoticz.
Thx, was the part I was looking for ^^. To resume the application deal directly with the domoticz's device using json.
lwolf
Post by lwolf »
From today commit, RPIEasy has an MQTT Autodiscovery controller, which should also work with Domoticz!
