Extract value from mqtt report Topic is solved
- amplituda
- Domoticz version: 2023.2
Greetings!)
I want to ask about the output of data on mqtt with domoticz
There is a clock with the ability to display information on mqtt, but I do not know how to choose the correct format for the mqtt topic name ...
installed the mosquitto broker and by subscription to all the topics in PuTTY
mosquitto_sub -h 192.168.1.2 -v -t "#"
I see info from all sensors in the form
domoticz / out {
Battery: 255,
RSSI: 12,
"Description": "",
"Dtype": "Temp",
"Id": "24351",
"Idx": 102,
"Name": "Street temperature",
"Nvalue": 0,
"Stype": "LaCrosse TX3",
"Svalue1": "-3.2",
"Unit": 31
The clock is connected to the same network with domoticz, and if in the clock settings I indicate the domoticz / out topic on the clock I see all this info ...
And how to draw only Street temperature -3.2 .....?
Probably need a script that will convert these values for output on mqtt
domoticz / out {
Battery: 255,
RSSI: 12,
"Description": "",
"Dtype": "Temp",
"Id": "24351",
"Idx": 102,
"Nvalue": 0,
"Svalue1": "-3.2",
"Unit": 31
- waaren
Re: Extract value from mqtt report
See the attached dzVents scriptamplituda wrote: Saturday 16 February 2019 6:39 Greetings!)
-- mqqt
on = { devices = { 24 }}, -- idx of your temperature sensor
execute = function(dz, item)
local function osExecute(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
assert(fileHandle:read('*a'))
fileHandle:close()
local mqttCommand = "mosquitto_pub -t domoticz/out -m '" .. item.name ..": " .. dz.utils.round(item.temperature,2) .. "'"
osExecute(mqttCommand)
}Debian buster, bullseye on RPI-4, Intel NUC.
- amplituda
Thank you for responding to my request)
I indicated this data in the script, now I see the following in the log:
Status: dzVents: Info: Handling events for: "Street temperature", value: "0.9"
Status: dzVents: Info: ------ Start internal script: MQTT: Device: "Street temperature (RFLink)", Index: 102
Status: dzVents: Info: ------ Finished MQTTplease tell me more)
- waaren
If you set the clock to listen to another topic, for instance clock/temperature and change the script to the attached, you should see something.
You can check on the command line with
mosquitto_sub -F "%U - %t - %p" -v -t '#'
-- mqqt
on = { devices = { 24 }}, -- idx of your temperature command
dz.log("Executing command: " .. cmd,dz.LOG_FORCE)
fileHandle:close()
local clockTopic = "clock/temperature"
local mqttCommand = "mosquitto_pub -t " .. clockTopic .. " -m '" .. item.name ..": " .. dz.utils.round(item.temperature,2) .. "'"
- amplituda
Yes, with the new script and the title of the clock / temperature topic, everything works as it should! Thank you very much for your help! You can close the topic - the problem is solved!waaren wrote: Saturday 16 February 2019 11:36 If you set the clock to listen to another topic, for instance clock/temperature and change the script to the attached, you should see something.
- waaren
You have to close it yourself as you started the topic.amplituda wrote: Saturday 16 February 2019 13:41 Yes, with the new script and the title of the clock / temperature topic, everything works as it should! Thank you very much for your help! You can close the topic - the problem is solved!
- amplituda
Hi waaren, and you will not tell me how to add more sensors?
- waaren
Is this a question or a statement ?amplituda wrote: Wednesday 27 February 2019 8:52 Hi waaren, and you will not tell me how to add more sensors?
I am not aware of a question in that direction; please elaborate ?
- amplituda
This is my bad English through a translator)
I ask for help on this script, can I add data from other sensors to it?
- waaren
Yes you can but for now limited to one topic and only for temperature devices.amplituda wrote: Thursday 28 February 2019 6:00 This is my bad English through a translator)
You can do that by adding more temperature devices to line 4 like
on = { devices = { 24, 37, 11 }}, -- idx of your temperature devicesDebian buster, bullseye on RPI-4, Intel NUC.
- amplituda
Thanks for your reply! I failed to do it correctly, now Hall temperature is constantly being transmitted, and the Street temperature is not visible, maybe this is because Hall temperature more often transmits sensor readings ...
Can it be possible to transmit both readings at the same time?
Status: dzVents: Info: Handling events for: "Hall temperature", value: "22.2;39;1"
Status: dzVents: Info: ------ Start internal script: MQTT: Device: "Hall temperature (RFLink)", Index: 222
Status: dzVents: !Info: Executing command: mosquitto_pub -t clock/temperature -m 'Hall temperature: 22.2'
Status: dzVents: Info: Handling events for: "Street temperature ", value: "1.8"
Status: dzVents: !Info: Executing command: mosquitto_pub -t clock/temperature -m 'Street temperature : 1.8'
Status: dzVents: Info: ------ Finished MQTT- waaren
Sure; but what should be the text ? Are you looking for something like Street temperature: 1.8, Hall temperature: 22.2 ? or do you want something else ?amplituda wrote: Thursday 28 February 2019 12:54 Thanks for your reply! I failed to do it correctly, now Hall temperature is constantly being transmitted, and the Street temperature is not visible, maybe this is because Hall temperature more often transmits sensor readings ...
Would it be possible to transmit both readings at the same time?
- amplituda
Yes, that's right, I want to get testimony at the same time Street temperature: 1.8, Hall temperature: 22.2
- waaren
Try thisamplituda wrote: Thursday 28 February 2019 16:53 Yes, that's right, I want to get testimony at the same time Street temperature: 1.8, Hall temperature: 22.2
-- mqqt
devices =
24,433, 591 -- idx of your temperature Sensors
data = { temperatures = { initial = {} } },
fileHandle:close()
dz.data.temperatures[item.name] = dz.utils.round(item.temperature,2)
local payload = ""
helper = {}
for n in pairs(dz.data.temperatures) do table.insert(helper, n) end
table.sort(helper)
for key, sensorName in ipairs (helper) do
payload = payload .. sensorName .. ": " .. dz.data.temperatures[sensorName] .. ", "
local mqttCommand = "mosquitto_pub -t " .. clockTopic .. " -m '" .. payload:sub(1, -3) .. "'"
- amplituda
Yes, now two sensors read at the same time! Thank you again!)
