Extract value from mqtt report Topic is solved
amplituda
Domoticz version: 2023.2
Post by amplituda »
Greetings!)
I want to ask about the output of data on mqtt with domoticz
There is a clock with the ability to display information on mqtt, but I do not know how to choose the correct format for the mqtt topic name ...
installed the mosquitto broker and by subscription to all the topics in PuTTY
mosquitto_sub -h 192.168.1.2 -v -t "#"
I see info from all sensors in the form
domoticz / out {
Battery: 255,
RSSI: 12,
"Description": "",
"Dtype": "Temp",
"Id": "24351",
"Idx": 102,
"Name": "Street temperature",
"Nvalue": 0,
"Stype": "LaCrosse TX3",
"Svalue1": "-3.2",
"Unit": 31
The clock is connected to the same network with domoticz, and if in the clock settings I indicate the domoticz / out topic on the clock I see all this info ...
And how to draw only Street temperature -3.2 .....?
Probably need a script that will convert these values ​​for output on mqtt
Re: Extract value from mqtt report
amplituda wrote: Saturday 16 February 2019 6:39 Greetings!)
See the attached dzVents script
-- mqqt
    on      =   {   devices         =   { 24 }}, -- idx of your temperature sensor
    execute = function(dz, item)
        local function osExecute(cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            assert(fileHandle:read('*a'))
            fileHandle:close()
        local mqttCommand  = "mosquitto_pub -t domoticz/out -m '" .. item.name ..": " .. dz.utils.round(item.temperature,2) .. "'"
        osExecute(mqttCommand)
amplituda
Post by amplituda »
waaren wrote: Saturday 16 February 2019 8:44 See the attached dzVents script
Thank you for responding to my request)
I indicated this data in the script, now I see the following in the log:
Status: dzVents: Info: Handling events for: "Street temperature", value: "0.9"
Status: dzVents: Info: ------ Start internal script: MQTT: Device: "Street temperature (RFLink)", Index: 102
Status: dzVents: Info: ------ Finished MQTT
but I do not understand where to get the correct name of the mqtt topic, to indicate in the settings of the clock .... that is, what should i replace domoticz / out to see Street temperature 0.9
please tell me more)
amplituda wrote: Saturday 16 February 2019 10:55 please tell me more)
If you set the clock to listen to another topic, for instance clock/temperature and change the script to the attached, you should see something.
You can check on the command line with
mosquitto_sub -F "%U - %t - %p" -v -t '#'
-- mqqt
    on      =   {   devices         =   { 24 }}, -- idx of your temperature command
 	     dz.log("Executing command: " .. cmd,dz.LOG_FORCE)
            fileHandle:close()
        local clockTopic = "clock/temperature"
        local mqttCommand  = "mosquitto_pub -t " .. clockTopic .. " -m '" .. item.name ..": " .. dz.utils.round(item.temperature,2) .. "'"
amplituda
Post by amplituda »
waaren wrote: Saturday 16 February 2019 11:36 If you set the clock to listen to another topic, for instance clock/temperature and change the script to the attached, you should see something.
Yes, with the new script and the title of the clock / temperature topic, everything works as it should! Thank you very much for your help! You can close the topic - the problem is solved!
amplituda wrote: Saturday 16 February 2019 13:41 Yes, with the new script and the title of the clock / temperature topic, everything works as it should! Thank you very much for your help! You can close the topic - the problem is solved!
You have to close it yourself as you started the topic.
amplituda
Post by amplituda »
Hi waaren, and you will not tell me how to add more sensors?
amplituda wrote: Wednesday 27 February 2019 8:52 Hi waaren, and you will not tell me how to add more sensors?
Is this a question or a statement ?
I am not aware of a question in that direction; please elaborate ?
amplituda
Post by amplituda »
This is my bad English through a translator)
I ask for help on this script, can I add data from other sensors to it?
amplituda wrote: Thursday 28 February 2019 6:00 This is my bad English through a translator)
Yes you can but for now limited to one topic and only for temperature devices.
You can do that by adding more temperature devices to line 4 like
   on      =   {   devices         =   { 24, 37, 11  }}, -- idx of your temperature devices
if you need other types of information and other topics then please specify in detail what you want / need and I will try to help
amplituda
Post by amplituda »
Thanks for your reply! I failed to do it correctly, now Hall temperature is constantly being transmitted, and the Street temperature is not visible, maybe this is because Hall temperature more often transmits sensor readings ...
Status: dzVents: Info: Handling events for: "Hall temperature", value: "22.2;39;1"
Status: dzVents: Info: ------ Start internal script: MQTT: Device: "Hall temperature (RFLink)", Index: 222
Status: dzVents: !Info: Executing command: mosquitto_pub -t clock/temperature -m 'Hall temperature: 22.2'
Status: dzVents: Info: Handling events for: "Street temperature ", value: "1.8"
Status: dzVents: !Info: Executing command: mosquitto_pub -t clock/temperature -m 'Street temperature : 1.8'
Can it be possible to transmit both readings at the same time?
amplituda wrote: Thursday 28 February 2019 12:54 Thanks for your reply! I failed to do it correctly, now Hall temperature is constantly being transmitted, and the Street temperature is not visible, maybe this is because Hall temperature more often transmits sensor readings ...
Would it be possible to transmit both readings at the same time?
Sure; but what should be the text ? Are you looking for something like Street temperature: 1.8, Hall temperature: 22.2 ? or do you want something else ?
amplituda
Post by amplituda »
Yes, that's right, I want to get testimony at the same time Street temperature: 1.8, Hall temperature: 22.2
amplituda wrote: Thursday 28 February 2019 16:53 Yes, that's right, I want to get testimony at the same time Street temperature: 1.8, Hall temperature: 22.2
Try this
-- mqqt
    on      =   {
                    devices  =
                                    24,433, 591                  -- idx of your temperature Sensors
    data    =  { temperatures = { initial = {} } },
            fileHandle:close()
        dz.data.temperatures[item.name] = dz.utils.round(item.temperature,2)
        local payload = ""
        helper = {}
        for n in pairs(dz.data.temperatures) do table.insert(helper, n) end
        table.sort(helper)
        for key, sensorName in ipairs (helper) do
            payload = payload ..  sensorName .. ": " .. dz.data.temperatures[sensorName] .. ", "
        local mqttCommand  = "mosquitto_pub -t " .. clockTopic .. " -m '" .. payload:sub(1, -3) .. "'"
amplituda
Post by amplituda »
Yes, now two sensors read at the same time! Thank you again!)
