Moving Domoticz to newer Pi
alarm_guy1
Post by alarm_guy1 »
Hi guys,
I have a RPi 2 and would like to move my domoticz to a Pi 3B+, as I think my system is a bit sluggish, sometimes there is a big delay between a sensor activating and a light coming on for example, so would like to migrate my system to a more powerful Pi, is this as simple as setting up Domoticz on the new Pi and importing my Backup and plugging in my USB?
Secondly could the below device be a bottle neck?
I am using an OpenZWave USB
Version: 1.4-2888-g54682370-dirty
I'm assuming this to now be a clone Everspring unit.
My 1st port of call is the Pi as I have one of them spare, then will add an external harddrive later
chers
Egregius
Domoticz version: v2024.7
Re: Moving Domoticz to newer Pi
Post by Egregius »
Define 'big' delay.
If you mean 0,8 to 1,2 seconds that's normal when using built-in scripting.
sincze
Domoticz version: 2024.4
Post by sincze »
Egregius wrote: Saturday 16 February 2019 8:31 Define 'big' delay.
In addition to @Egregius, did you have a look at the cpu/system load ?? e.g. top or htop when the pi2 is in use?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
alarm_guy1
sorry been away for the weekend,
generally the delay is as indicated, however it can be as much as 20 seconds
I will see if the Pi is running hard
cheers
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
