I use an Domoticz on my Synology NAS. Now I try to discover Dashticz. First I download the file "dashticz V2". I changes the Config file.
Now my question is what are the following steps? In which folder have I place the file? Did you changed something on the Synology? I can't find anything about this. The only tutorials I can find they descripe about the raspberry Pi.
Install Dashticz Synology
Braadkippie
- Screenshotv8.JPG (153.48 KiB) Viewed 3862 times
Lokonli
Re: Install Dashticz Synology
There are more people using Synology. Feel free to add installation instructions for Synology on the wiki:Braadkippie wrote: Tuesday 12 February 2019 23:36 I use an Domoticz on my Synology NAS. Now I try to discover Dashticz. First I download the file "dashticz V2". I changes the Config file.
https://www.domoticz.com/wiki/Dashticz_ ... stallation
First advice: Use the beta branch, not the master branch. The master branch is pretty old, and only works for the basic functionality.
Steps
* Install/activate WebStation via Package Station
* Install/activate PHP via Package Station
* Via Main Menu -> Web station select your preferred HTTP backend server
(assumption: nginx)
* At the same page verify that an PHP version is activated.
* In "Web station" -> "PHP settings" verify that the curl extension is selected.
* Download the latest Dashticz beta branch and copy the complete branch to the www-root-folder.
Assumption: the name of your dashticz folder is dashticz_v2
For nginx on Synology the www root folder is /usr/share/nginx/html
Now you should have a folder /usr/share/nginx/html/dashticz_v2
* Edit custom/CONFIG.js with the basic settings according the installation instructions on the Wiki
Probably you have to set the correct file permissions:
chmod -R a+rX /usr/share/nginx/html/dashticz_v2
and if you want to be able to save your settings from the Dashtics menu:
chmod a+w /usr/share/nginx/html/dashticz_v2/custom/CONFIG.js
Now Dashticz should run on http://[IP of Synology-nas]/dashticz_v2
Braadkippie
Thanks a lot Lokonli. So I understand now what the webstation mean. But I have now a problem. The steps you told, I've done. But now I get an fould 404. Do you know what is wrong? (see printscreens)
Ps. I download the file Dashticz from this URL: https://github.com/Dashticz/dashticz_v2 ... c30862827c
- Screenshotv9.JPG (190.4 KiB) Viewed 3826 times
- Screenshotv10.JPG (55.62 KiB) Viewed 3826 times
- Screenshotv11.JPG (133.12 KiB) Viewed 3826 times
Last edited by Braadkippie on Thursday 14 February 2019 20:49, edited 1 time in total.
Braadkippie
And another printscreen
- Screenshotv12.JPG (161.02 KiB) Viewed 3825 times
trijet
Re: Install Dashticz Synology SOLVED
I have the same issue and 404
However I got 1 step further.
Found that login in with
http://MyIP:8084/dashticz_v2/index.html
give me this:
Same screen with my Synology and my RPi with both services approachable.
SOLVED
Got it to work, the target directory is wrong.
You need to install the dashticz_V2 folder in:
/volume1/web
approach with:
IP/dashticz_V2
give me this:
SOLVED
/volume1/web
approach with:
IP/dashticz_V2
ZaGaPonG
Hi guys,
On Syno, that's really simple:
- Install the package "Web Station"
- Download the zip from "beta" branch and paste it into your "web" folder directly with "File Station"
- Unzip the zip with "File Station"
- Your Dashticz will be available at this address: your.ip/yourdashticzfolder (eg: 192.168.0.50/dashticz)
