detecting analog doorbell
SweetPants
Re: detecting analog doorbell
Try using a (bridge) rectifier and capacitor to convert the AC->DC and use an opto coupler to connect it to your raspberry GPIO.
- l0gic
- Domoticz version: Latest
I did similar, 8v(ish) ac fully rectified gave me around 12v dc. I used this to operate a relay connected to a MySensors board.SweetPants wrote: Sunday 27 January 2019 19:29 Try using a (bridge) rectifier and capacitor to convert the AC->DC and use an opto coupler to connect it to your raspberry GPIO.
Opto would be just as good, I had a relay in my spares box but no opto's
Been solid as a rock for a few years now.
Non credus crepitus
- l0gic
Just a guess but perhaps the AC changes (50Hz) is too fast for the reed to react.sander815 wrote: Sunday 27 January 2019 20:26 ok
but why doesn't the xiaomi door sensor(reed switch) pick up the magnetic field?
I tried using a reed switch route originally but couldn't get it to work even if I laid it on the coil.
Hence I went for a bridge rectified relay.
Kevin
Non credus crepitus
freijn
- Domoticz version: Stable
Something like this
instead of GND you can use +5 I prefer using the internal pull up and then to GND
- Capture.JPG (57.59 KiB) Viewed 1215 times
SweetPants
Maybe add a capacitor over + and -. Now you get a 100Hz signal on your relayfreijn wrote: Monday 28 January 2019 9:53 Something like this
