If you study the working example scripts on this forum ( combined devices / time , cancelQueuedCommands() and os.execute ) you should have enough information on how to build your dzVents script. Please feel free to ask if you don't understand the logic in any of these examples.Mayki wrote: Tuesday 22 January 2019 10:39 I need to be in the time period between 23:00 and 6:30 they turned on the lights, but only if not already switched on in some other way. Five minutes without moving to turn off again. But I want them to shine through the night mode. Which in the LUA script is set as follows:
Can you please help me?
dzVents for motion sensor
- waaren
Re: dzVents for motion sensor
- waaren
Probably over complicated but you still might find it useful.Mayki wrote: Tuesday 22 January 2019 20:26 I needed to help with :Code: Select all
if (light.active) then light.switchOff().afterMin(5) else light.switchOn().forMin(5) end
Motion sensor "PIR chodba" Idx 27
Yeelight ceiling "Světlo chodba" Idx 14 and "Světlo hala" Idx 19
local runcommandbaby = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 1, 500]}\\r\\n"
local nightTime = {"at 21:00-06:30" }
devices = {
["PIR chodba"] = nightTime , -- PIR need to react during nightTime
"Světlo chodba","Světlo hala" , -- controlling selector devices
timer = {
"every 5 minutes between 23:00 and 06:30",
"at 06:32",
logging = {
level = domoticz.LOG_DEBUG,
marker = "PIRTest"
execute = function(dz, item)
local function logWrite(str,level) -- Support function for shorthand debug log statements
dz.log(tostring(str),level or dz.LOG_DEBUG)
local chodba = dz.devices("Světlo chodba")
local hala = dz.devices("Světlo hala")
local PIR = dz.devices("PIR chodba")
local function getLevel( levels, search ) -- support function to get level (0,10,20 etc.. based on levelNames)
for index,levelName in ipairs(levels) do
logWrite("getLevel, index: " .. index .. " ==>> " .. levelName .. " " .. search )
if search == levelName then return ( ( index - 1 ) * 10 ) end
return nil
local function setLight(t,key) -- This function does the actual work
if not t[key] then
logWrite("No such defined setting (" .. key .. ")" ,dz.LOG_ERROR)
return
logWrite("Found " .. key .." ==> " .. t[key] )
local osCommand = "sudo echo -ne " .. t[key] .. " \\r\\n | " .. t.executable .. t.parm .. t.address .. t.port .. t.background
logWrite("Sending command: \r\n" .. osCommand)
os.execute(osCommand)
logWrite("Calculated level: " .. getLevel(t.levels,key))
t.device.switchSelector(getLevel(t.levels,key)).silent() -- update the selector to reflect the new level but prevent loop
local chodbaControls = -- Table with all relevant settings
device = chodba,
Off = '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}',
["Bright 25%"] = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 25, 500]}',
["Bright 50%"] = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 50, 500]}',
["Bright 75%"] = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 75, 500]}',
Sunrise = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]}',
Sunset = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",24,2,\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\"]}',
["4-7-8"] = '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"cf\",24,2,\"4000,2,400[0,30,7000,2,4000,10,8000,2,4000,1\"]}',
Baby = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 1, 500]}',
levels = {"Off","Bright 25%","Bright 50%","Bright 75%","Sunrise","Sunset","4-7-8","Baby"},
executable = "/opt/bin/ncat",
parm = " -w1 ",
address = "192.168.0.112 ",
port = " 55443",
background = " &"
local halaControls =
device = hala,
Sunrise = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,1,\"50,2,4000,1,900000,2,4000,100\"]}',
Sunset = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]}',
["4-7-8"] = '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"cf\",24,2,\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\"]}',
parm = " -w1 ",
address = "192.168.0.105 ",
port = " 55443",
background = " &"
if item.isTimer and dz.time.matchesRule("at 06:32") then -- switch Off in the morning
setLight(chodbaControls,"Off")
setLight(halaControls,"Off")
elseif item.isTimer and PIR.lastUpdate.minutesAgo > 5 and PIR.lastUpdate.minutesAgo < 15 then -- No activity during the night ?
if hala.level ~= halaControls.BabyLevel then setLight(halaControls,"Baby") end -- switch to baby mode if not already there
if chodba.level ~= chodbaControls.BabyLevel then setLight(chodbaControls,"Baby") end
elseif item.name == "Světlo chodba" then -- triggered by manual selector change
setLight(chodbaControls,item.levelName)
elseif item.name == "Světlo hala" then
setLight(halaControls,item.levelName) -- triggered by manual selector change
elseif item.name == "PIR chodba" and item.isActive then
setLight(halaControls,"Baby") -- PIR see something
-- test / debug only
if _G.logLevel == dz.LOG_DEBUG then
for key, value in pairs(halaControls) do
logWrite(key .." => " .. tostring(value))
} Debian buster, bullseye on RPI-4, Intel NUC.
- waaren
Sorry to hear that. Does the command work if you enter it manually ? I am asking because I tried it on my yeelights and it does not work for me. Not from dzVents but also not if I enter it from the commandline.
- waaren
The only difference I see it that the original Lua script use a relative path and dzVents (and you from the CLI) use a full qualified path to ncatMayki wrote: Thursday 24 January 2019 10:55 I do not understand if, I use the dummy switch "Scény chodba" that controls the LUA script, I choose BABY mode, the light turns on.
What is the difference between what Domoticz sends from a LUA script or I through CMD?
Where is the binary ncat on your system ?
[EDIT]
When I use netcat in the commandline and leave out the single quotes it works from the command line. I now "only" have to get the command to the os without losing the quotes. Need some time to puzzle so don't expect anything soon.
- waaren
I understand but in your Lua example I see that opt/bin is used. So if domoticz base directory is /home/pi , I expect that the Lua will look inMayki wrote: Thursday 24 January 2019 12:42waaren wrote: Thursday 24 January 2019 12:29 The only difference I see it that the original Lua script use a relative path and dzVents (and you from the CLI) use a full qualified path to ncat
Where is the binary ncat on your system ?Code: Select all
login as: root [email protected]'s password: root@DiskStation:~# cd .. root@DiskStation:/# cd /opt/bin root@DiskStation:/opt/bin# ls ash find grep islebe localedef.new locale.new ncat netstat opkg sh xargs root@DiskStation:/opt/bin#
/home/pi/opt/bin
The dzVents script use /opt/bin and will look in the /opt/bin
Please correct me if I am wrong.
- waaren
Got it working on my system. Can you check what your result is on yours ?
local runcommandbaby = "sudo echo -ne '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 1, 500]}\\r\\n"
devices = {
["XButton-1"] = nightTime ,
timer = {
"at 06:32",
logging = {
marker = "PIRTest"
return nil
if not t[key] then
return
local osCommand = "sudo echo -ne " .. t[key] .. "\\r\\\\n | " .. t.executable .. t.parm .. t.address .. t.port ..";"
local osCommand = "sudo echo -ne " .. t[key] .. "\\r\\\\n | " .. t.executable .. t.parm .. t.address .. t.port .. "; > fff.log"
device = chodba,
Off = '{\\"id\\":1,\\"method\\":\\"set_power\\", \\"params\\":[\\"off\\", \\"smooth\\", 500]}\\',
["Bright 25%"] = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 25, 500]}\\',
["Bright 50%"] = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 50, 500]}\\',
["Bright 75%"] = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 75, 500]}\\',
Sunrise = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,2,\\"50,2,4000,75,900000,2,4000,1\\"]}\\',
Sunset = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",24,2,\\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
["4-7-8"] = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",24,2,\\"4000,2,400[0,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
Baby = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 1, 500]}\\',
parm = " -w2 ",
port = " 55443",
background = " &"
device = hala,
Sunrise = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,1,\\"50,2,4000,1,900000,2,4000,100\\"]}\\',
Sunset = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,2,\\"50,2,4000,75,900000,2,4000,1\\"]}\\',
["4-7-8"] = '{\\"id\\":1,\\"method\\":\\"set_scene\\",\\"params\\":[\\"cf\\",24,2,\\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
parm = " -w2 ",
port = " 55443",
background = " &"
-- logWrite(key .." => " .. tostring(value))
- waaren
It is my understanding that Svetlo chodba and Svetlo hala are selector switches bothe with levelnames asMayki wrote: Saturday 26 January 2019 14:17 Meanwhile outside night time ...
2019-01-26 13:56:47.348 Status: dzVents: Info: Handling events for: "Světlo hala", value: "Off" 2019-01-26 13:56:47.348 Status: dzVents: Info: PIRTest: ------ Start internal script: PIR test: Device: "Světlo hala (YeeLight)", Index: 19 2019-01-26 13:56:47.349 Status: dzVents: Debug: PIRTest: Processing device-adapter for Světlo chodba: RGB(W) device adapter 2019-01-26 13:56:47.349 Status: dzVents: Debug: PIRTest: Processing device-adapter for Světlo chodba: Switch device adapter 2019-01-26 13:56:47.350 Status: dzVents: Debug: PIRTest: Processing device-adapter for PIR chodba: Switch device adapter 2019-01-26 13:56:47.350 Status: dzVents: Error (2.4.11): PIRTest: An error occured when calling event handler PIR test 2019-01-26 13:56:47.350 Status: dzVents: Error (2.4.11): PIRTest: ...oticz/var/scripts/dzVents/generated_scripts/PIR test.lua:52: attempt to concatenate local 'key' (a nil value) 2019-01-26 13:56:47.350 Status: dzVents: Info: PIRTest: ------ Finished PIR test
Off, Bright 25%,Bright 50%,Bright 75%,Sunrise, Sunset,4-7-8 and Baby
Can you confirm that ?
- waaren
That explains the error.
I send the an updated script via PM as I don't want to bather everyone on the forum.
I will post the endresult here when without problems
