dzVents for motion sensor
Re: dzVents for motion sensor
Mayki wrote: Tuesday 22 January 2019 10:39 I need to be in the time period between 23:00 and 6:30 they turned on the lights, but only if not already switched on in some other way. Five minutes without moving to turn off again. But I want them to shine through the night mode. Which in the LUA script is set as follows:
Can you please help me?
If you study the working example scripts on this forum ( combined devices / time , cancelQueuedCommands() and os.execute ) you should have enough information on how to build your dzVents script. Please feel free to ask if you don't understand the logic in any of these examples.
Mayki wrote: Tuesday 22 January 2019 20:26 I needed to help with :
if (light.active) then
	light.switchOff().afterMin(5)
	light.switchOn().forMin(5)
Probably over complicated but you still might find it useful.
Motion sensor "PIR chodba" Idx 27
Yeelight ceiling "Světlo chodba" Idx 14 and "Světlo hala" Idx 19
    local runcommandbaby = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 1, 500]}\\r\\n"
local nightTime = {"at 21:00-06:30" }
            on =    {
                        devices =    {
                                         ["PIR chodba"] =  nightTime ,      -- PIR need to react during nightTime
                                         "Světlo chodba","Světlo hala"  ,    -- controlling selector devices
                        timer   =   {
                                        "every 5 minutes between 23:00 and 06:30",
                                        "at 06:32",
    logging =   {
                    level     =   domoticz.LOG_DEBUG,
                    marker    =   "PIRTest"
    execute = function(dz, item)
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local chodba        = dz.devices("Světlo chodba")
        local hala          = dz.devices("Světlo hala")
        local PIR           = dz.devices("PIR chodba")
        local function getLevel( levels, search )             -- support function to get level (0,10,20 etc.. based on levelNames)
            for index,levelName in ipairs(levels) do
                logWrite("getLevel, index: " .. index .. " ==>> " .. levelName .. " " .. search )
                if search == levelName then return ( ( index - 1 ) * 10 ) end
            return nil
        local function setLight(t,key)                        -- This function does the actual work
            if not t[key] then
                logWrite("No such defined setting (" .. key .. ")" ,dz.LOG_ERROR)
                return
                logWrite("Found " .. key .." ==> " .. t[key] )
                local osCommand = "sudo echo -ne " .. t[key] .. " \\r\\n | " .. t.executable .. t.parm .. t.address .. t.port .. t.background
                logWrite("Sending command: \r\n" .. osCommand)
                os.execute(osCommand)
                logWrite("Calculated level: " ..  getLevel(t.levels,key))
                t.device.switchSelector(getLevel(t.levels,key)).silent()            -- update the selector to reflect the new level but prevent loop
        local chodbaControls =                                                       -- Table with all relevant settings
                device          = chodba,
                Off             = '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}',
                ["Bright 25%"]  = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 25, 500]}',
                ["Bright 50%"]  = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 50, 500]}',
                ["Bright 75%"]  = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 75, 500]}',
                Sunrise         = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]}',
                Sunset          = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",24,2,\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\"]}',
                ["4-7-8"]       = '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"cf\",24,2,\"4000,2,400[0,30,7000,2,4000,10,8000,2,4000,1\"]}',
                Baby            = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 1, 500]}',
                levels          = {"Off","Bright 25%","Bright 50%","Bright 75%","Sunrise","Sunset","4-7-8","Baby"},
                executable      = "/opt/bin/ncat",
                parm            = " -w1 ",
                address         = "192.168.0.112 ",
                port            = " 55443",
                background      = " &"
        local halaControls =
                device          = hala,
                Sunrise         = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,1,\"50,2,4000,1,900000,2,4000,100\"]}',
                Sunset          = '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]}',
                ["4-7-8"]       = '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"cf\",24,2,\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\"]}',
                parm            = " -w1 ",
                address         = "192.168.0.105 ",
                port            = " 55443",
                background      = " &"
        if item.isTimer and dz.time.matchesRule("at 06:32") then               -- switch Off in the morning
            setLight(chodbaControls,"Off")
            setLight(halaControls,"Off")
        elseif item.isTimer and PIR.lastUpdate.minutesAgo > 5 and PIR.lastUpdate.minutesAgo < 15 then  -- No activity during the night ?
            if hala.level ~= halaControls.BabyLevel then setLight(halaControls,"Baby") end             -- switch to baby mode if not already there
            if chodba.level ~= chodbaControls.BabyLevel then setLight(chodbaControls,"Baby") end
        elseif item.name == "Světlo chodba" then                    -- triggered by manual selector change
            setLight(chodbaControls,item.levelName)
        elseif item.name == "Světlo hala" then
            setLight(halaControls,item.levelName)                   -- triggered by manual selector change
        elseif item.name == "PIR chodba" and item.isActive then
            setLight(halaControls,"Baby")                           -- PIR see something
        -- test / debug only
        if _G.logLevel == dz.LOG_DEBUG then
            for key, value in pairs(halaControls) do
                logWrite(key .." => " .. tostring(value))
Sorry to hear that. Does the command work if you enter it manually ? I am asking because I tried it on my yeelights and it does not work for me. Not from dzVents but also not if I enter it from the commandline.
Mayki wrote: Thursday 24 January 2019 10:55 I do not understand if, I use the dummy switch "Scény chodba" that controls the LUA script, I choose BABY mode, the light turns on.
What is the difference between what Domoticz sends from a LUA script or I through CMD?
The only difference I see it that the original Lua script use a relative path and dzVents (and you from the CLI) use a full qualified path to ncat
Where is the binary ncat on your system ?
[EDIT]
When I use netcat in the commandline and leave out the single quotes it works from the command line. I now "only" have to get the command to the os without losing the quotes. Need some time to puzzle so don't expect anything soon.
Mayki wrote: Thursday 24 January 2019 12:42
waaren wrote: Thursday 24 January 2019 12:29 The only difference I see it that the original Lua script use a relative path and dzVents (and you from the CLI) use a full qualified path to ncat
login as: root
[email protected]'s password:
root@DiskStation:~# cd ..
root@DiskStation:/# cd /opt/bin
root@DiskStation:/opt/bin# ls
ash  find  grep  islebe  localedef.new  locale.new  ncat  netstat  opkg  sh  xargs
I understand but in your Lua example I see that opt/bin is used. So if domoticz base directory is /home/pi , I expect that the Lua will look in
/home/pi/opt/bin
The dzVents script use /opt/bin and will look in the /opt/bin
Please correct me if I am wrong.
Mayki wrote: Thursday 24 January 2019 15:33 I use Domoticz installed on NAS Synology
Got it working on my system. Can you check what your result is on yours ?
    local runcommandbaby = "sudo echo -ne '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 1, 500]}\\r\\n"
            on =    {
                        devices =    {
                                         ["XButton-1"]  =  nightTime ,
                        timer   =   {
                                        "at 06:32",
    logging =   {
                    marker    =   "PIRTest"
            return nil
            if not t[key] then
                return
                local osCommand = "sudo echo -ne " .. t[key] .. "\\r\\\\n  | " .. t.executable .. t.parm .. t.address .. t.port ..";"
                local osCommand = "sudo echo -ne " .. t[key] .. "\\r\\\\n | " .. t.executable .. t.parm .. t.address .. t.port .. "; > fff.log"
                device          = chodba,
                Off             = '{\\"id\\":1,\\"method\\":\\"set_power\\", \\"params\\":[\\"off\\", \\"smooth\\", 500]}\\',
                ["Bright 25%"]  = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 25, 500]}\\',
                ["Bright 50%"]  = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 50, 500]}\\',
                ["Bright 75%"]  = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 75, 500]}\\',
                Sunrise         = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,2,\\"50,2,4000,75,900000,2,4000,1\\"]}\\',
                Sunset          = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",24,2,\\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
                ["4-7-8"]       = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",24,2,\\"4000,2,400[0,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
                Baby            = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"bright\\", 1, 500]}\\',
                parm            = " -w2 ",
                port            = " 55443",
                background      = " &"
                device          = hala,
                Sunrise         = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,1,\\"50,2,4000,1,900000,2,4000,100\\"]}\\',
                Sunset          = '{\\"id\\":1,\\"method\\":\\"set_scene\\", \\"params\\":[\\"cf\\",2,2,\\"50,2,4000,75,900000,2,4000,1\\"]}\\',
                ["4-7-8"]       = '{\\"id\\":1,\\"method\\":\\"set_scene\\",\\"params\\":[\\"cf\\",24,2,\\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\\"]}\\',
                parm            = " -w2 ",
                port            = " 55443",
                background      = " &"
                -- logWrite(key .." => " .. tostring(value))
Mayki wrote: Saturday 26 January 2019 14:17 Meanwhile outside night time ...
2019-01-26 13:56:47.348 Status: dzVents: Info: Handling events for: "Světlo hala", value: "Off"
2019-01-26 13:56:47.348 Status: dzVents: Info: PIRTest: ------ Start internal script: PIR test: Device: "Světlo hala (YeeLight)", Index: 19
2019-01-26 13:56:47.349 Status: dzVents: Debug: PIRTest: Processing device-adapter for Světlo chodba: RGB(W) device adapter
2019-01-26 13:56:47.349 Status: dzVents: Debug: PIRTest: Processing device-adapter for Světlo chodba: Switch device adapter
2019-01-26 13:56:47.350 Status: dzVents: Debug: PIRTest: Processing device-adapter for PIR chodba: Switch device adapter
2019-01-26 13:56:47.350 Status: dzVents: Error (2.4.11): PIRTest: An error occured when calling event handler PIR test
2019-01-26 13:56:47.350 Status: dzVents: Error (2.4.11): PIRTest: ...oticz/var/scripts/dzVents/generated_scripts/PIR test.lua:52: attempt to concatenate local 'key' (a nil value)
2019-01-26 13:56:47.350 Status: dzVents: Info: PIRTest: ------ Finished PIR test
It is my understanding that Svetlo chodba and Svetlo hala are selector switches bothe with levelnames as
Off, Bright 25%,Bright 50%,Bright 75%,Sunrise, Sunset,4-7-8 and Baby
Can you confirm that ?
That explains the error.
I send the an updated script via PM as I don't want to bather everyone on the forum.
I will post the endresult here when without problems
