Display the result of a script into the Dashboard Topic is solved
julien92
Domoticz version: 4.9701
Post by julien92 »
I’ll ask a newbie question (I’m discovering Domoticz since 2 weeks, and everything that could be done with it :D ).
I would like to know if it would be possible to display within a widget the result of a bash script.
For instance (some basic examples) :
- display in the widget the number of files within a folder
- or, the 3 last lines of a log file
- or the name / IP address of the last user who connected to the openVPN server (or FTP server)
- and so on…
The aim is to add, into domoticz dashboard, not only values related to physical equipment (temperature and so on…) but also values that are obtained with scripts.
Thanks a lot in advance.
Julien
julien92
Re: Display the result of a script into the Dashboard
Post by julien92 »
I've tried to execute the shell script with the push button, but there is no way to display the result.
I've also tried to look around the text device, but the value of this keeps displaying "hello world" :roll:
julien92 wrote: Friday 18 January 2019 16:59 I would like to know if it would be possible to display within a widget the result of a bash script.
Use this in your bash script
curl "http://domoticzIP:domoticzPort/json.htm?type=command&param=udevice&idx=<id of your text device>&svalue=yourText"
julien92
Post by julien92 »
Hi Waaren
Thanks for your feedback.
But can you please give me some more precision?
My Domoticz IP is : 192.168.1.45
port : 8082
Id of the text device : 34
so the command would be :
curl "http://192.168.1.45:8082/json.htm?type= ... e=yourText"
But let's assume I would like to use this shell script (basic, just for the example) :
myscript.sh (located into /home/pi/domoticz/scripts)
#!/bin/bash
echo "Today is $(date)" > /dev/null 2>&1
=> How could I tell to domoticz to use the scipt located in /home/pi/domoticz/scripts/myscript.sh ?
Many thanks in advance!! :) :)
julien92 wrote: Friday 18 January 2019 22:51 My Domoticz IP is : 192.168.1.45
port : 8082
script (make sure it can be executed by domoticz (chmod 755) :
#!/bin/bash
myvar=$(date)                 # get date string in var
myvar="${myvar// /%20}"       # prepare for curl (replace spaces with %20)
curl  "http://192.168.1.45:8082/json.htm?type=command&param=udevice&idx=34&svalue=$myvar"
create a dummy switch and put in the on section: script:///home/pi/domoticz/scripts/myscript.sh
Make sure to use 3 ///
on Action.png (58.66 KiB) Viewed 1360 times
julien92
Post by julien92 »
Thanks a lot Waaren :)
But still one question : will the result of the script be displayed if I use a switch as device?
If so, where would it be supposed to be displayed?
(that's why I fisrt tried to use "text" device type)
Thanks again for your help, much appreciated! ;)
julien92 wrote: Saturday 19 January 2019 0:00 Thanks a lot Waaren :)
No the switch is only used here to have a method to trigger the bash script. The bash script will send the text (here date) to a text device.
julien92
Post by julien92 »
Hi Waaren,
Many thanks for your help ! It works fine, I’m now able to display text within a widget thanks to your help by indicating :
#!/bin/bash
curl  http://192.168.1.45:8082/json.htm?type=command&param=udevice&idx=34&svalue=$myvar
This will allow me to display text, as long as the text only stands into one unique line.
Nevertheless, I’m now struggling with another point. I’m aware this is not related to Domoticz, but rather to general linux / shell scripting skills.
My goal is to display the content of a log file (for example the 5 last lines of a log file).
That why I’m now looking at how replacing the line break by the matching hexadecimal value.
For replacing the “space”, your command was quite easy (even if I didn’t know it until now ;) :
But I don’t know how to apply the same kind of action for the line break, as the character which needs to be replaced needs to be typed in…
Hexadecimal value for line break is “0A”.
So I’ve tried with :
myvar2="${myvar1//\n/%0A}"
But that returns :
curl: (3) Illegal characters found in URL
Would you have any idea about that?
That would be really great! 
Thanks a lot in advance!
Julien
julien92 wrote: Sunday 20 January 2019 21:11 ...So I’ve tried with :
You are close..
Try
myvar2="${myvar1//\\n/%0A}"
julien92
Post by julien92 »
Thanks for your reply Waaren.
Unfortunately, that does not work...
I've tried with :
myvar3="${myvar2//\\n/%0A}"
and
myvar3="${myvar2// \\n/%0A}"
and
myvar3="${myvar2// \ \n/%0A}"
But each time, when trying to execute the script, I get this result :
pi@raspberrypi:~/domoticz/scripts $ ./myscript.sh
julien92
Post by julien92 »
I've found the solution to replace line break by its hexadecimal character. It must be like this :
myvar3="${myvar2//$'\n'/%0A}"
It's more or less by chance that I've found that, by trying some ideas found on different websites.
Do you confirm this syntax is correct, indeed? :)
I've then made the conversion of other symbols.
Here is my complete script to display the openvpn logs into a dummy text device :
myvar1="$(cat /var/log/openvpn.log)"
myvar2="${myvar1// /%20}"
# replaces the spaces by its hexadecimal character
# replaces the line breaks by its hexadecimal character
myvar4="${myvar3//[/%5B}"
# replaces the [ by its hexadecimal character
myvar5="${myvar4//]/%5D}"
# replaces the ] by its hexadecimal character
curl "http://192.168.1.45:8082/json.htm?type=command&param=udevice&idx=30&svalue=$myvar5"
# sends the myvar5 variable through curl
By the way, do you know if there would be a way to apply all the conversions into one single line? (to avoid using 5 variables).
Julien
julien92 wrote: Wednesday 23 January 2019 23:17
My system/ shell behaves different (debian stretch / GNU bash, version 4.4.12(1))
Only one var needed...
myvar="test [1]\n\rtest [2]\n\rtest [3]\n\r"
echo -en "$myvar"
test [1]
test [2]
test [3]
myvar="${myvar//\\n/%0A}" # LF
myvar="${myvar//\\r/%0D}" # CR
myvar="${myvar//[/%5B}"   # [
myvar="${myvar//]/%5D}"   # ]
myvar="${myvar// /%20}"   # space
echo $myvar
test%20%5B1%5D%0A%0Dtest%20%5B2%5D%0A%0Dtest%20%5B3%5D%0A%0D
curl "http://PI-4:8084/json.htm?type=command&param=udevice&idx=1445&nvalue=0&svalue=$myvar"
   "status" : "OK",
   "title" : "Update Device"
send text.png (6.15 KiB) Viewed 1280 times
Lisa3746
Post by Lisa3746 »
Hi there! Sorry to intervene but I have got the same question and I cannot get my head around it.
I have got a php script which reads an JSON API and get a string as follows: Temperature 30.1C
Now I want to display this result in the dashboard and I cannot understand how to do it. Happy to run crontab every 60 secs but how to display this in the dashboard? Many thanks for any help.
Lisa3746 wrote: Monday 27 July 2020 18:27 I have got a php script which reads an JSON API and get a string as follows: Temperature 30.1C
Now I want to display this result in the dashboard and I cannot understand how to do it. How to display this in the dashboard?
Can you share your script an how it is executed now?
Is the script executed on the same system as domoticz?
What is the id and type, subtype of the target device ?
Lisa3746
Post by Lisa3746 »
Sure, here is my script:
#!/usr/bin/php
<?php
$json_string = file_get_contents ("https://api.example.com");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'];
echo "Temperature ".$parsed_json."C"."\n";
Yes, the script is on the same system in ../domoticz/scripts
I do not yet have a device for the script, this is why I posted the question here. The script clearly works but how to parse the answer into Dashboard and keep it updated...
Lisa3746 wrote: Monday 27 July 2020 20:01 Yes, the script is on the same system in ../domoticz/scripts
create a virtual sensor type temperature. Write down the idx of the new device and insert it in this php and schedule it in cron with the required frequency
#!/usr/bin/php
<?php
$DomoticzURL = 'http://127.0.0.1:8080/json.htm?'; // assuming domoticz uses port 8080
$temperatureDevice = '1168'; // change 1168 with IDX of your virtual temperature device
$URL = $DomoticzURL.'type=command&param=udevice&idx='.$temperatureDevice.'&nvalue=0&svalue='.$parsed_json;
file_get_contents($URL);
Lisa3746
Post by Lisa3746 »
Gosh...I do not know what to say, you are genius! Many thanks for you help, I can now read the temperature every X seconds :D
