Sunset/sunrise blockly Topic is solved
maceddy
Domoticz version: 12723
Post by maceddy »
I want my garden lights to go on or off only at certain times.
For example: if sunset is before 22:00 turn on the lights at sunset.
I wrote some blockly for this, but my garden lights are not being turned on.. I can not figure out what I am doing wrong...
tozzke
Domoticz version: Stable
Re: Sunset/sunrise blockly
Post by tozzke »
First of all... if you're only using one statement, you'll have to pick the other if-block without the blue gear icon on the top left.
Secondly you can't compare 'Sunset' directly to a specific time
this'll work better I guess:
maceddy
Post by maceddy »
I can see the logic in that. I am gonna try that! Thanks.
Plantje
Post by Plantje »
Until what time does "> sunset" apply? I mean: at about 22.00 it is past sunset. But at 3 in the night it is also past sunset. However, after 9.00 in the morning, it is also past sunset....past sunrise as well.
I am asking this, because I'd like my bathroom lights to switch on to 100% when it is daytime and to 10% when it is nighttime.
Is it also possible to check if it is 2 hours past sunset? Or do I just have to make sure the action set will happen "after x minutes"?
Treve
Domoticz version: v4.11474
Post by Treve »
Plantje wrote: Friday 31 July 2020 22:59 Until what time does "> sunset" apply? I mean: at about 22.00 it is past sunset. But at 3 in the night it is also past sunset. However, after 9.00 in the morning, it is also past sunset....past sunrise as well.
You can make use of a "dummy switch" and set timers in this switch, for instance A daytime block, after Sunrise - set on, after Sunset - set off.
Now you will have a switch wich is on during Sunrise and Sunset.
For a Nighttime block, set ,after Sunset on, after Sunrise set off.
Now you will have a switch wich is on during Sunset and Sunrise.
With this switch you can finish the block with other blockly components.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Plantje
Post by Plantje »
Quite weird to have a virtual switch to control an actual switch.
Anyway, thanks for the response, but I solved it by checking the LUX.
Aantekening 2020-08-01 105046.png (80.86 KiB) Viewed 4886 times
Treve
Post by Treve »
Because there is no linear connection from Lux to Sunset/Sunrise. Lots of people struggle with time calculations and use of a dummy makes the blockly quite easy.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Plantje
Post by Plantje »
I know time calculation is always a pain :( I am in BI en proper reporting against time is always challenging!
However, in this case if I were to switch a light based on if it is after sunset or not then I fail to see why I would first switch a dummy switch based on if it is after sunset and then based on the dummy switch, switch the actual switch. It seems redundant.
Treve
Post by Treve »
There are several roads that lead to Rome, I just try to make another way clear and not to offer a solution. In retrospect, my comment applies more to the "maceddy" problem. My point is that time-related problems can be (temporarily) solved and tested with dummies and variables. Then you can make an attempt to solve this neatly without the dummy(s) and variables.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Plantje
Post by Plantje »
Agreed.... let's not hijack this topic any further :)
phpieter
Post by phpieter »
When one has setup a blockly like: time > sunset OR time < sunrise —> activate device.
You now wonder why its not working. And it looks like sunrise and sunset are being ignored. There is a good change you did not setup your location in the settings page of domoticz.
Longitude and Latitude are required for sunrise/sunset to work in blockly.
