Zigate with Osram Lightify / Smart+ Motion Sensor / no values
pocock
Post by pocock »
I'm running Domoticz with the Zigate plugin.
I was able to join the Osram Smart+ (formerly Lightify) Motion sensor but I observe the following problems:
- each attribute (e.g. battery voltage) appears twice in Domoticz
- the temperature is always 0 degrees
- the battery voltage is always 0 V
- the switch state never changes (looking at the log view, it is always closed)
Could this simply be a faulty motion sensor, should I try to get it replaced? Or is it not fully supported yet?
Is there anything more I can do to troubleshoot this sensor?
Daniel Pocock, Debian Developer
https://danielpocock.com
pipiche
Re: Zigate with Osram Lightify / Smart+ Motion Sensor / no values
Post by pipiche »
Hard to say.
I don't have one personally, so cannot really confirm if it works out of the box , or if it requires some fine tuning.
Logs would help, if you are able to put the logs in regards to some specific actions/expectations.
It short this would requires further investigation
pipiche
Post by pipiche »
https://zigate.fr/produits-osram-compatibles-zigate/
Looks like the Motion sensor is not fully cooperative with Zigate ;-)
I'll investigate
pipiche
Post by pipiche »
Could you try on Beta version ?
And provide me the DeviceList-xx.txt (at least the related entry for the OSRMA Motion Sensor)
