Problems with Darksky script
Steef
Post by Steef »
Hello Domoticz fanatics,
My name is Steef, and I am exploring the (endless) possibilities of the Domoticz workaround.
I have Domoticz running on a Raspberry Pi 3b, running on Raspbian.
Because I would really like to receive detailed weather information, I am trying to follow a nice how-to I found on the internet: https://ehoco.nl/domoticz-weerstation/ (The how-to is in Dutch).
I followed the how-to, but somehow, I receive an error on the following line:
commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
The error I receive is: Error: EventSystem: in Darksky weerstation: [string ” –[[ WEERSTATIONS: …”]:36: attempt to concatenate field ‘?’ (a nil value)
The complete script is mentioned below. I am trying to understand the .lua language, but it is new to me, and can not find the error.
Is there anyone who can help me with this problem? many thanks!
--[[ WEERSTATIONS:
Amsterdam   = 36  Groningen           = 13  Oost-Groninigen = 31  Vlissingen      = 44
Arnhem      = 2   Hoek van Holland    = 17  Oost-Overijssel = 12  Voorschoten     = 46
Berkhout    = 3   Hoogeveen           = 18  Rotterdam       = 33  Wadden          = 19
Den Helder  = 6   Leeuwarden          = 26  Utrecht         = 5   Weert           = 8
Eindhoven   = 7   Lelystad            = 27  Terneuzen       = 47  West-Friesland  = 38
Gilze Rijen = 10  Maastricht          = 29  Twente          = 41  West-Utrecht    = 28
Goes        = 11  Noord-Groninigen    = 24  Uden            = 45  Woensdrecht     = 50
Gorinchem   = 16  Noordoostpolder     = 30  Venlo           = 1   Zwolle          = 15
---------- SETTINGS ------------
local domo_ip       = "lokaal IP plus poort"          -- IP adres van Domoticz, inclusief poort
local weerstation   = 15                                    -- Kies je weerstation naar keuze
local api_key       = "API key"    -- Darksky secret key
local debug         = 0                                     -- 0 = no debug, 1 = debug
local language      = "nl"                                  -- ar: Arabic, az: Azerbaijani, be: Belarusian, bg: Bulgarian, bs: Bosnian, ca: Catalan, cs: Czech, da: Danish,
			-- de: German, el: Greek, en: English, es: Spanish, et: Estonian, fi: Finnish, fr: French, he: Hebrew, hr: Croatian,
			-- hu: Hungarian, id: Indonesian, is: Icelandic, it: Italian, ja: Japanese, ka: Georgian, ko: Korean, kw: Cornish,
			-- lv: Latvian, nb: Norwegian Bokmål, nl: Dutch, no: Norwegian Bokmål (alias for nb), pl: Polish, pt: Portuguese,
			-- ro: Romanian, ru: Russian, sk: Slovak, sl: Slovenian, sr: Serbian, sv: Swedish, tet: Tetum, tr: Turkish,
			-- uk: Ukrainian, x-pig-latin: Igpay Atinlay, zh: simplified Chinese, zh-tw: traditional Chinese
local dev_TempGround    = "GrondTemperatuur"       -- Temperature sensor
local dev_TextTomorrow  = "Verwachting morgen"      -- Text sensor
local dev_LongText      = "Uitgebreide verwachting"  -- Text sensor
local dev_DewPoint      = "Dauwpunt"                -- Temperature sensor
local dev_CloudCover    = "Bewolkingsgraad"         -- Percentage sensor
local dev_UV            = "UV"                      -- UV sensor
local dev_Ozone         = "Ozone"                   -- Custom sensor with axis "DU"
--Functie devices updaten
if commandArray == nil then commandArray = {} end
function UpdateDev(device,nvalue,svalues)
-- Functie afronding
function round(num, dec)
if num == 0 then
return 0
local mult = 10^(dec or 0)
return math.floor(num * mult + 0.5) / mult
----- ######## Buienradar API Data call ######## -----
time = os.date("*t")
if  ((time.min+2)%5)==0  then -- Script loopt iedere 5 minuten (bv. 11.03, 11.08, 11.13, 11.18, etc.
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
local config=assert(io.popen('curl "https://api.buienradar.nl/data/public/2.0/jsonfeed"'))
local Stringjson = config:read('*all')
config:close()
local jsonData = json:decode(Stringjson)
-- Convert the json to a LUA table
if jsonData.actual.stationmeasurements[ weerstation ] ~= nil then  -- this sometimes happens around midnight
val_TempGround              = jsonData.actual.stationmeasurements[ weerstation ].groundtemperature
val_WeatherTomorrow         = jsonData.forecast.fivedayforecast[1].weatherdescription
val_SunChanceTomorrow       = jsonData.forecast.fivedayforecast[1].sunChance
val_RainChanceTomorrow      = jsonData.forecast.fivedayforecast[1].rainChance
val_RainMinimum             = jsonData.forecast.fivedayforecast[1].mmRainMin
val_RainMaximum             = jsonData.forecast.fivedayforecast[1].mmRainMax
val_WindDirectionTomorrow   = jsonData.forecast.fivedayforecast[1].windDirection
val_WindSpeedTomorrow       = jsonData.forecast.fivedayforecast[1].wind
val_TempTomorrowMinMin      = jsonData.forecast.fivedayforecast[1].mintemperatureMin --minimale minimumtemperatuur
val_TempTomorrowMaxMin      = jsonData.forecast.fivedayforecast[1].mintemperatureMax --maximale minimumtemperatuur
val_TempTomorrowMinMax      = jsonData.forecast.fivedayforecast[1].maxtemperatureMin --minimale maximumtemperatuur
val_TempTomorrowMaxMax      = jsonData.forecast.fivedayforecast[1].maxtemperatureMax --maximale maximumtemperatuur
--Min/Max. temperatuur bepalen
if val_TempTomorrowMinMin == val_TempTomorrowMaxMin then TempMinimum = val_TempTomorrowMinMin
else TempMinimum = val_TempTomorrowMinMin.." - "..val_TempTomorrowMaxMin end
if val_TempTomorrowMinMax == val_TempTomorrowMaxMax then TempMaximum = val_TempTomorrowMinMax
else TempMaximum = val_TempTomorrowMinMax.." - "..val_TempTomorrowMaxMax
--Regenhoeveeldheid bepalen
if val_RainMinimum == val_RainMaximum then RainIntensity = val_RainMinimum
else RainIntensity = val_RainMinimum.." - "..val_RainMaximum end
-- Windrichting tekst bepalen
if val_WindDirectionTomorrow == "z" or val_WindDirectionTomorrow == "Z" then WindDirectionTomorrow = " het zuiden"
elseif val_WindDirectionTomorrow == "zw" or val_WindDirectionTomorrow == "ZW" then WindDirectionTomorrow = "het zuidwesten"
elseif val_WindDirectionTomorrow == "zo" or val_WindDirectionTomorrow == "ZO" then WindDirectionTomorrow = "het zuidoosten"
elseif val_WindDirectionTomorrow == "w" or val_WindDirectionTomorrow == "W" then WindDirectionTomorrow = "het westen"
elseif val_WindDirectionTomorrow == "nw" or val_WindDirectionTomorrow == "NW" then WindDirectionTomorrow = "het noordwesten"
elseif val_WindDirectionTomorrow == "n" or val_WindDirectionTomorrow == "N" then WindDirectionTomorrow = "het noorden"
elseif val_WindDirectionTomorrow == "no" or val_WindDirectionTomorrow == "NO" then WindDirectionTomorrow = " het noordoosten"
elseif val_WindDirectionTomorrow == "o" or val_WindDirectionTomorrow == "O" then WindDirectionTomorrow = "het oosten"
else WindDirectionTomorrow = "variabele richtingen" end
--Voorspellingen
forecast=val_WeatherTomorrow.. "\n " .."\n".. "Komende nacht daalt de temperatuur naar "..TempMinimum.." °C. Morgen overdag wordt morgen maximaal "..TempMaximum.. " °C. Er is morgen "..val_SunChanceTomorrow.." % kans op zon en "..val_RainChanceTomorrow.." % kans op neerslag ("..RainIntensity.." mm). De wind komt uit "..WindDirectionTomorrow.." en zal kracht "..val_WindSpeedTomorrow.." Bft hebben." .."\n " .."\n "
if otherdevices_svalues[dev_TextTomorrow] ~= forecast then UpdateDev(dev_TextTomorrow,0,forecast) end
-- Updating domoticz devices
UpdateDev(dev_TempGround,0,val_TempGround)
if debug==1 then
print ("Temperatuur grond: "..val_TempGround.." °C")
-- ######## Darksy API call ######## --
local config=assert(io.popen('curl "http://'..domo_ip..'/json.htm?type=settings"'))
config:close()
lat          = jsonData.Location.Latitude
lon          = jsonData.Location.Longitude
local coord = lat..","..lon
local config=assert(io.popen('curl "https://api.darksky.net/forecast/'..api_key..'/'..coord..'?lang='..language..'&units=si&exclude=hourly,flags"'))
config:close()
if jsonData ~= nil then  -- this sometimes happens around midnight
val_UV          = jsonData.currently.uvIndex
val_Ozone       = jsonData.currently.ozone
val_DewPoint    = round(jsonData.currently.dewPoint,1)
val_CloudCover  = jsonData.currently.cloudCover*100
if debug==1 then
print("Bewolkingsgraad : "..val_CloudCover.. " %")
print("UV-kracht :"..val_UV)
print("Ozone : De ozone-waarde is "..val_Ozone)
print("Dauwpunt : "..val_DewPoint.. " °C")
-- Domoticz devices updaten
UpdateDev(dev_CloudCover,0,val_CloudCover)
UpdateDev(dev_DewPoint,0,val_DewPoint)
UpdateDev(dev_UV,0,val_UV..";0")
UpdateDev(dev_Ozone,0,val_Ozone)
if debug==1 then
print ("Dauwpunt: "..val_DewPoint.." °C")
print ("Bewolkingsgraad: "..val_CloudCover.." %")
print ("UV-Index: "..val_UV)
print ("Ozone: "..val_Ozone)
-- ######## Buienradar Verwachting API call ######## --
if  ((time.min+2)%30)==0  then -- Script loopt iedere 30 minuten (bv. 11.28, 11.58, 12.28, 12.58, etc.
local config=assert(io.popen('curl "https://api.buienradar.nl/data/public/1.1/jsonfeed"'))
config:close()
val_LongText   = jsonData.buienradarnl.weergegevens.verwachting_vandaag.titel .."\n " .."\n ".. jsonData.buienradarnl.weergegevens.verwachting_vandaag.tekst .."\n " .."\n"
if debug==1 then
print ("Uitgebreid: "..val_LongText)
if otherdevices_svalues[dev_LongText] ~= val_LongText then UpdateDev(dev_LongText,0,val_LongText) end
wallgarden
Re: Problems with Darksky script
Post by wallgarden »
I have exactly the same error.
Did you find a solution?
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
zicht
Domoticz version: 2023.1+
Post by zicht »
wallgarden wrote: Monday 11 March 2019 18:33 I have exactly the same error.
Thanks for pointing me to this script will give it a try next week....
Just a quick reply on the errors you see :
The error says one of the strings in line 36 is empty. Empty value is not possible after .. in lua
You could use the print() command in lua to write something to the log.
like :
print(device)
print(nvalue)
print(svalues)
place it before the error and look in the log when it is executed.
it will give you a clue about what is going on
Do not forget to insert you domoIP !
You also need to have the dummy sensors in place with idx mentioned in the local dev_ section just above...
wallgarden
Thank you "zicht" for your reply.
I solved the problem already.
My solution was found in in the handling of the sensor "Groundtemperature".
The device for the sensor had the discription: "Temperatuur grond", while the script was refering to "Temperature Ground".
Thank you again.
Regards,
Wallgarden
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
gielie
Domoticz version: latest β
Post by gielie »
I also have some problems with this script, i get this error.
 2019-04-04 10:54:01.032 Error: EventSystem: Lua script Darksky did not return a commandArray
this is the code i use
 --[[ WEERSTATIONS:
Amsterdam   = 36  Groningen           = 13  Oost-Groningen  = 31  Vlissingen      = 44
Goes        = 11  Noord-Groningen     = 24  Uden            = 45  Woensdrecht     = 50
local domo_ip       = "***"					-- IP adres van Domoticz, inclusief poort
local weerstation   = 36                                    -- Kies je weerstation naar keuze
local api_key       = "***"    -- Darksky secret key
local debug         = 1                                     -- 0 = no debug, 1 = debug
local dev_TempGround    = "Temperatuur Grond"       -- Temperature sensor
local dev_LongText      = "Verwachting uitgebreid"  -- Text sensor
local dev_DewPoint      = "Temperatuur Dauwpunt"    -- Temperature sensor
    if(commandArray == nil) then
        commandArray = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
    if num == 0 then
        return 0
    local config=assert(io.popen('curl "https://data.buienradar.nl/2.0/feed/json"'))
    config:close()
--Voorspellingen
forecast=val_WeatherTomorrow.. "\n" .."\n".. "Komende nacht daalt de temperatuur naar "..TempMinimum.." °C. Morgen overdag wordt morgen maximaal "..TempMaximum.. " °C. Er is morgen "..val_SunChanceTomorrow.." % kans op zon en "..val_RainChanceTomorrow.." % kans op neerslag ("..RainIntensity.." mm). De wind komt uit "..WindDirectionTomorrow.." en zal kracht "..val_WindSpeedTomorrow.." Bft hebben." .."\n " .."\n "
if debug==1 then
    print ("Temperatuur Grond: "..val_TempGround.." °C")
    config:close()
    config:close()
    if debug==1 then
if debug==1 then
    local config=assert(io.popen('curl "https://data.buienradar.nl/1.1/feed/json"'))
    config:close()
  if debug==1 then
if otherdevices_svalues[dev_LongText] ~= val_LongText then UpdateDev(dev_LongText,0,val_LongText)end
Does anybody know where this error comes from, the sensors are being updated tho.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Users browsing this forum: Ahrefs [Bot] and 1 guest
